Thread: Depth of sports pool & slide
    Depth question. We were going to go 3 to 5 to 3.5 on other side.
    Thoughts/suggestions? To shallow? Bad slope?
    Not doing slide now, but want to in future. Do I have them plumb for it now? Does it require plumbing/water?
    Pool: 18000 gal w/ spill over spa Pump: 3HP Intelliflo VS 011018 Booster: 1.5HP Sta-Rite Dyna-Max Filter: 300 sqft Sta-Rite System 3 Heater: Rheem RayPak 399 BTUH Chlorinator: ClevaChlor RP30HD Controller: Jandy iAquaLink RS PS8 PDA Cleaner: Pentair Pool Shark Plumbing: 2"
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Depth of sports pool & slide
    Yes, it requires plumbing. How wide is the pool? I think 5' is probably deep enough (barely, maybe), but if it's not wide enough it won't be safe.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What type of sports are you wanting to play?
    What type of pool surface will there be?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    It's 18x36 and we want it for volleyball basketball and lounging
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Plaster? Vinyl? 5' is pretty deep at the net? Mines 3.5 at the net and I can barely spike, I'm 6'1". In our deep end at 4' it's really tough to move fast in the water....
    18'x43' Sport Pool
