Results 1 to 9 of 9
Thread: Pool is in!
    Jun 2013
    Clarksville Tennessee
    28
    Pool is in!
    Pool is about halfway full. Electric is going in today. Still need to back fill a little. Hoping we don't get too much rain tonight that makes a muddy mess.
    20' X 40' IG, 35900 gallons, Hayward Sand Filter w/1.5hp Super Pump, Hayward Aqua Rite SWG
    Pool installed 2009 TF-100 test kit. Clarksville TN
    22,543
    Re: Pool is in!
    Looks good so far!
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Pool is in!
    Jun 2013
    28
    Re: Pool is in!
    Thanks. The rain stopped my electrician today. Wife just called and said water is just about to the skimmer and looks to have a very light green color. What can I do now before the water gets to the right level and my power is hooked up?
    Jan 2012
    'burbs of Augusta, Georgia
    7,271
    Re: Pool is in!
    Add some bleach and get it stirred around in there however you can. Also start adding your CYA so that you keep the chlorine in there. Check out the pool calculator for quantities.
    Jun 2013
    28
    Re: Pool is in!
    Pool was fine. I believe my wife is color blind or something. Its now completely full. Electrician just called and said power is installed and pump is circulating water. Going to test the water when I get off work and go from there.
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Re: Pool is in!
    I have the same stairs...enjoy!
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    Jun 2013
    28
    Re: Pool is in!
    Pump is up and running. Added bleach last night. CYA is dissolving. Stairs going in tonight.
    Sep 2012
    Mid-Michigan
    127
    Re: Pool is in!
