Results 1 to 15 of 15
Thread: pH and TA
    Jun 2011
    Lakewood, NJ
    62
    pH and TA
    I've had phenomenal results using the TFP method the last 3 years. Looking forward to a fantastic TFP season.
    We just opened our pool this morning and here are the results
    FC 0
    CC 0
    pH 7.5
    TA 40
    CYA 0
    The pH is perfect should I adjust TA before I start shocking.
    I will place some granules in a sock at the return to raise CYA.
    Thanks, Hannah
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    5) Hayward pro-grid 2420, 1 hp, 96 gpm
    Also have Dolphin diagnostic 2001
    22,553
    Re: pH and TA
    If your TA really is 40 ppm then you probably do want to raise it at least a little. First thing I'd do is retest it.
    how old are the reagents?
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    Chlorine and pH testing are from last year, CYA liquid, this year, the remainder 2 years.
    thanks for the quick response
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    22,553
    Re: pH and TA
    Since the reagents for TA are two years old I might get a second opinion before you adjust it.
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    I retested at 3 pm after adding baking soda
    FC 3
    CC 1
    pH 7.8
    TA 70
    CYA 0
    should I adjust the pH?
    I added conditioner already.
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: pH and TA
    How does your water look?
    As for adjusting ph...since your TA was low (were you/are you using trichlor pucks or dichlor?) I would wait and see what your ph does. If it goes up at all, I would then lower it down to 7.5 or so.
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    I've been shocking for 5 hours now and the algae/water is starting to turn milky gray. I will not adjust the pH anymore everything seems to be on course.
    do you agree?
    Thanks for you help
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: pH and TA
    Yes, proceed with the shocking process.
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    The pool is getting clearer. However this morning I performed 2 readings
    9 am
    FC 11
    CC .5
    pH 7.5
    TA 70
    10 am
    FC 8.5
    CC .5
    pH 7.3
    TA 70
    also CYA still registers 0. I only put in about 16 oz of conditioner, should I put some more in? and should I increase the pH levels.
    Thanks
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    Re: pH and TA
    16 oz of conditioner/CYA is nowhere near enough. 16 oz in 22000 gallons would raise CYA by 6.5 or so, and you want to raise CYA up to the 30 to 50 range.
    With CYA that low you will lose chlorine to sunlight very rapidly.
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    should I add a full 4 lb bottle of conditioner. I remember from last season, starting out with 0 CYA in the pool and adding less than a 4 lb bottle initially, I ended up with CYA levels of 30 during the season. I don't use any tabs.
    Also, should I raise the pH?
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    Jun 2011
    Long Beach, CA
    2,790
    Re: pH and TA
    Put in all 4 lbs of conditioner, if your pool volume is correct then it should only raise it a little over 20.
    Leave the pH alone, it is ideal for the shock process.
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    10:15 am reading
    FC 9.5
    CC 0.
    pH 7.2 or 7.1
    TA 80
    CYA 20
    last night 11 pm
    FC 11
    CC 1
    pH 7.2
    TA 80
    CYA
    the water is crystal clear now yesterday it was filmy. I think I'm done shocking.
    should I adjust the pH now. or wait for the CC to lower.
    Thanks for your help,
    Hannah
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    Re: pH and TA
    Keep the FC level at shock level until CC is 0.5 or lower for 12 hours (or more).
    Jun 2011
    Lakewood, NJ
    62
    Re: pH and TA
    Just tested the water 6:40 pm
    FC 8
    CC 0
    pH 7.2/7.1
    TA 80
    CYA 20
    I'll be gone until Saturday night, should I raise the pH now, should I leave it?
    I will now add 2 jugs of 6% bleach just in case.
    Who is in charge of thepoolcalculator.com? Great Value bleach now comes in 121 oz jugs, not 128 oz.
    Thanks for the great site
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
