Thread: TA and pH questions
    TA and pH questions
    We have a 20 X 40 X 32 inground, indoor, vinyl pool. I have the hardest time keeping the pH up. I consistently have to put about 4 lbs of soda ash in each day and it makes the pool cloudy. We use an automatic feeder for the chlorine and acid which are liquid feeders. We have an unusually large bather load through swim lessons. I am looking to improve the clarity of the water. Any suggestions? I was thinking of putting in a new filter and pump and adding a UV filter.
    Re: TA and pH questions
    Make sure the acid feed system is properly adjusted. You don't want the acid feed system constantly adding acid while you are manually adding soda ash.
    Are there any other chemicals that get added to the pool regularly?
    Adding soda ash causing clouding suggests that some of your other levels are out of balance. Could you post a complete set of water test results?
    It would be nice if you setup your signature line. We don't get very many indoor pools, so without a reminder that yours is indoors you will tend to get outdoor pool advice, which is often different.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    I would stop any addition of Acid until you get your pH stable. Soda Ash and Acid are working against each other.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
