Thread: Filter
    Filter
    Good days everyone,
    Just a small question when is it better to run the filter? During the day or during the night? I understand the pool water has to cycle a few times but was curious as to when is better.
    Please and thank you
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Filter
    There's no difference as far as the filter is concerned - it will filter the same day or night.
    Absent any obvious debris that needs to be filtered/vacuumed out, I run my filter when adding chemicals. If you use liquid bleach/chlorine (like me), I would dose in the early evening when no sunlight is hitting the pool. Since the filter should be on when adding any chemical to the pool, I would run it for at least 30 minutes after the last chemical addition or as long as needed to keep the water clear and/or vacuum.
    Refer to this article to determine pump run time: Determine Pump Run Time
