Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Hayward skimmer thru intex wall. Any tips?
    Just bought a large DE filter on ebay for my 15'x 48" intex. I like overkill. Planning on hard plumbing a hayward skimmer thru the wall. Ive seen some informative posts here on that but most of the pics are unviewable. Any suggestions with regards to preventing leaks? Has anyone used silicone in conjunction with the butterfly gasket? Should I cut the gasket in order to make it 2 piece so I can cut the hole thru the wall after installing skimmer, or just put the whole gasket on the inside of the wall? Any tips would be appreciated.
    25k IG pebble pool (resurfaced '09), Pentair "Triton II Commercial" 100c sand filter (without a multiport), 1.5HP Jandy/AO Smith pump, Barracuda G3 (dedicated line)
    Apr 2012
    SW Ohio
    456
    Re: Hayward skimmer thru intex wall. Any tips?
    that is the way I done mine use a razor blade or exact knife and make sure you leave no lip on the gasket and tighten evenly and securely.....no silicon needed if done correctly......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Thanks Mike, Did you cut new holes thru the wall for returns? I want to go 1 1/2 pvc, just need to figure out how to get a good seal.
    Apr 2012
    SW Ohio
    456
    your pool has the 1 1/4 holes correct?
    if so order 2-1 1/2 intex return eyeball assemblies
    go to lowes and buy 6 part #e 996h in the electric plastic conduit aisle
    and while your there pick up a 1/8 inch thick piece of rubber gasket material and a assortment of 1 1/2 sch 40 elbows 45 degree and 90 degree and 20 foot of 1 1/2 sch 40 pvc pipe.
    your gonna have to come up with some of the larger 1 1/2 intex nuts that come on the hoses in the larger intex pools to make the connections
    Jul 2010
    Jacksonville, NC
    35
    MOUNT THE SKIMMER BEFORE CUTTING THE HOLE!!!!
    Trust me....you do NOT what to cut before mounting!
    24' X 54" Sharkline Matrix. J-Hook liner.
    2 speed pump, 16" Intex sand filter.
    Apr 2012
    SW Ohio
    456
    exactly what bmarley5780 said
    cut the butterfly gasket in half with a razor blade or exacto knife trimming off any lip or if that scares you go to the pool store and buy 2 RUBBER gaskets for you skimmer (take butterfly gasket with you to match them up). Another good tip is to use a small torpedo level and level the inside faceplate and mark the 2 top outside holes with a sharpie, and drill those 2 holes and mount the skimmer tighten snugly and with someone on the outside of the pool holding the skimmer tight against the liner install remaining screws all tightened snugly once all screws are in with a correct sized screwdriver tighten all screws in a star fashion hook up all hose and cut out opening...CAREFULLY!!!!!!!!
    New to TFP and so far there seems to be great information here. Has anyone had their through wall skimmer installed for an extended time period (a year or more)? I want to do this to my INtex 26' Ultra Frame but I am worried that over time the cut could start to tear from the stress on the wall. I may be overly cautious but have only had the pool for a month and want to make sure I do not ruin it.
    Intex Ultra Frame 26' x 52"
    Hayward SP1092WM Through Wall Skimmer
    Intex 2650 GPH Sand FIlter & Pump
    Apr 2012
    SW Ohio
    456
    2 years here and no issues at all, it is a great mod for your intex plus the ability to vacuhm the pool efficiently is a win win situation......
    Awesome! Thanks for the reply. Only other thing to ask is did you reinforce the wall with patch material or do just have the single thickness vinyl? I am going to order the skinner to do the modification. Sounds like the way to go. Thanks again.
    Apr 2012
    SW Ohio
    456
    no reinforcement the intex is plenty thick.......Mike
    Jun 2013
    Minnesota
    36
    Mike, where did you order this?
    I've got the 2560 Sand Pump and it comes with 2 returns, are those the same thing or good enough?
    --- Pool Status - Ice Cube
    18'x9'x52" Intex Rectangular Pool with Krystal Clear 2560gpm Sand Pump and Krystal Clear Salt Water System
    Hayward Skimmer with (2) 1 1/2" Hayward Returns
    16mil Klear Choice Solar Blanket
    Jun 2013
    Minnesota
    36
    Jul 2009
    S. California
    157
    Just to chine in, when you cut the Hayward gasket in half, it's OK to not further trim or worry about the rough edge from the knife. Simply turn that side of the gasket away from the pool on each side. This leaves the perfectly smooth side against the pool, and wont interfere with the seal.
    I only say this because I can see how trying to trim that little rough edge could cause more harm than good in the process. If you're anal, careful and patient, then go for it.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Quote Originally Posted by fast1971chevelle
    Followed fast1971chevelle's advice and installed the Hayward SP1091WM (wide mouth) skimmer this evening. I also used a die grinder to remove the lip that protrudes through the wall from the faceplate. By doing this I was able to tighten everything up before cutting the vinyl. I never even drained any water, just dried and oiled my screwdriver really well when I was done. No leaks, works great! Its been running for about 3 hours now and the water already looks better. I may try the BBB method next.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by JC_First
    Let me tell you, you will love it too. We put up a new, larger Intex pool this spring and ditched the Intex salt-water chlorine generator that had given us fits for two years. Using the BBB method, knowing exactly what is going into the water and where exactly you stand, is very reassuring. I have my FC between 4 and 6 while I'm slowly raising the CYA with dichlor, and the water has never been nicer. Although a bit chilly at times, the kids are getting a lot of use out of it already. The only time I smell chlorine is when I'm rinsing out their suits in the bathroom sink!
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jul 2009
    Houston, Tx
    19
    I have read many threads on this topic, and most replies include instructions to cut the butterfly gasket in half. I had the hayward skimmer on my previous 18 x 52 pool (3 yrs.) and have one on my current pool ( 1 yr.). I didn't cut the gasket, just installed it on the water side of the pool wall, and haven't had the slightest leak. On my current pool, I did order the slightly less expensive hydro tools skimmer from amazon, and it came with a split rubber gasket. It leaked from the get go. After fighting the leak for a week I broke down and ordered the hayward again. No leak!
    John
    Intex 22 x 52 Ultra frame, 10,400 gals
    Intex 2600 gl/hr sand filter
    Quote Originally Posted by gd5015
    John
    Thanks John, That's what I was thinking of trying, good to hear from someone who's had success with that. I still have not started the project because my DE filter wont arrive 'till next Tuesday.
    I've also read of people lowering the water line and making the cut successfully before installing the skimmer, but the comments here have me leaning away from that. Obviously for the fish eye returns I'll have to make a cut prior to install, above the water line there doesn't seem to be a ton of tension on the liner. Thanks for the tips everyone. Eric
    On the return eyeball, should I just be making my existing 1 1/4" holes a little larger to accommodate 1 1/2"
    Apr 2012
    SW Ohio
    456
    Black noir I ordered them off amazon but is the 2650 gph pump comes with them use them.....Mike
  20. Back To Top    #20
    Apr 2012
    SW Ohio
    456
    Just center the 1 1/2 eyeball over the 11/4 hole and mark around with a sharpie and CAREFULLY cut out new hole....
    Make sure you have a new razor or exacto blade in the knife and go SLOWLY!!!!!!!!..... check and see if new eyeball will fit through exhisting hole first.......Mike
