Results 1 to 10 of 10
Thread: Plumbing renovation, checking for leaks and need to backfill
    Jun 2013
    Metrowest Massachusetts
    9
    Additional info, it took 2&1/2 days from 930 til dark, 60 feet of PVC, 13 street elbows, 28 normal 90s, and all the valves.
    I like the simplicity to run the spa from the everyday operation. Only need to turn two valves.
    Check it out.
    Tfpools,
    I'm replumbing, and gonna start next week. I've attached before shots.
    Current problems include:
    chlorinator runs through all returns including spa, so when heated and not chlorine turned down or off spa water gets super chlorinated,
    Booster pump breaks off before spa, so when spa running booster valve must be closed else spa drains.
    Plans include:
    Jandy 3 way, 2 ways, and checks
    Hayward unions
    Spa vs. all other suctions with 3 way
    Dual skimmers with 3 way
    Wall drain with 2way
    Close unions on pump and multiport valve
    Heater diverted with 3-way and check
    3-way to separate spa return from others
    Booster pump pulled from returns after spa diverter
    Then chlorinator, then 3 way to wall returns
    Using the mitre saw for cuts, red hot PVC cement for glue (Oatey or Christy's)
    Plenty of Teflon tape and magic lube II
    Other tips are welcomed.
    Dan
    Dan
    18' x 36' and 8' to 3' D vinyl, 26,500 gallon Cl- 8.25% Bleach, Pro 244T, 2HP Super Pump, PB4 Booster for a 280
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Plumbing renovation
    Welcome to tfp, danringer
    The first thing that comes to mind when looking at your plan is I wouldn't worry about moving the chlorinator. That is a trichlor puck chlorinator, and constant use will quickly raise your cya level high. Here at tfp we do not recommend trichlor feeders as the regular source of chlorine. See this pool school article: http://www.troublefreepool.com/pool-..._chlorine_pool
    To me it looks like the positioning of the plumbing is going to make some of your plans hard if not impossible. I don't see how your going to isolate the spa vs all other suction with a 3 way. I would use a 3 way to divert one side to spa/skimmer and wall drain/broken skimmer. Then a 3 way to divert between spa and skimmer and another for wall drain and broken skimmer. i would have the same set up on the return side. Since your not automating, you have to go turn the spa valves anyway, so i dont really see what the problem with closing the booster too.
    30,419
    This is just a bit off the main point, but however you end up re-plumbing, I suggest you switch to Jandy or Pentair valves and get rid of those cheaper ball valves. I initially installed the ball valves and each one of mine became unusable after about 4 years. I had to replace them all and have been troublefree since.
    Jun 2013
    9
    Quote Originally Posted by linen
    50 lbs of 3" sticks lasts me a season May-October in South Jersey, how much liquid Cl- would I need in a typical season for 18000 IGP? and can I purchase it at once for the whole season? My CYA has never been out of control with these 99% 4.5" sticks. But I like liquid Cl- for opening and fixing problems fast.
    Dan
    Jun 2013
    9
    Quote Originally Posted by keene3b07
    I'm gonna dig, and make the impossible possible! I definitely want to entertain automation for the future, so the single 3 way to plumb out the spa (suction and return) is a priority. I want to make the switch from pool to spa easy enough for my wife to use when I'm at work, I'd like to minimize the valves necessary and leave it automation ready for the next year or two.
    Dan
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Something does not add up
    50 lbs of trichlor will raise your 18000 gallon pool to 182 ppm cya...an extremely high amount On top of that, it is unlikely you are starting very low in the spring if this is your standard method of chlorinating, so you end of season cya level is likely even higher than that
    And here is another confusing part of the equation...as your cya goes up the amount of FC needed to maintain (safely) a algae free pool also goes up. Lets say at the beginning of the year, due to draining for the winter and other water changes getting pool ready, you are at 100 ppm cya at that point you need to maintain a minimum FC level of 8 ppm. At the end of the season with 100 + 182 = 282 ppm cya you need to maintain a minimum FC level of 21 ppm
    Quote Originally Posted by danringer
    If you shot for a reasonable cya of 50 ppm, dosed to 6 ppm everyday to stay above 4 ppm (assuming 1/3 lost to the sun), then I approximate it might take about 51 gallons of 12.5% liquid chlorine for 6 months.
    Jun 2013
    9
    I've replaced 7 of them and 3 more need to be replaced now ( barely turn without a wrench). I bought 5 jandy neverlube 3-way, one 2-way and 1 jandy check valve.
    thank you all for contributions so far
    -Dan
    Dan
    Jun 2013
    9
    If you shot for a
    wow! Local pool store always says my stabilizer is low and says my sticks are ****, i by them online from intheswim.com and not from him, he even sold me 4 lbs of CYA to bring it up this year. I recently denounced using the local pool store, bought your tftestkit, and while I'm learning the kit I still use the dip sticks to compare.
    Today's tftestkit:
    pH=7.2
    FC=7ppm
    CC=0.5ppm
    TC=7.5ppm
    TA=75
    CH=415
    CYA=70
    Dip stick:
    pH=7.2
    FC=5-10 (pad color between 5-10)
    TA=120
    CYA=30-50 (between pads)
    I do lower the level pretty far to winterize, and vacuum to waste when opening and top off with well water (filtered) maybe that accounts for the low CYA with these sticks or they may be **** like the guy says and not have enough stabilizer which may make them behave better by not overrunning the pool with CYA
    Dan
    Jun 2013
    9
    Re: Plumbing renovation, checking for leaks and need to back
    Had to make a new post for the rear pic. Over the file size limit.
    Dan
