Results 1 to 8 of 8
Thread: Estimating gallons
    Estimating gallons
    Hi, I'm learning that the previous pool owner was either a liar or completely clueless. Pool light issues, depth of pool we were told about, etc.
    Now, I was told we have an 18k gallon pool. I'm thinking it is quite a bit less than that based on what I can figure using wiki.
    Free form pool
    22 ft long
    Widest width 14 ft
    Narrowest width 11 ft
    Shallow end 3 ft
    Deep end 6 ft
    7 ft wide jacuzzi(round)
    How many gallons do you think my pool really is( including jacuzzi)?
    Thanks friends
    New pool owner 3/2013 14,000 gal pebble tec, 7 ft jacuzzi with spillover into pool.
    FNS +48 DE filter, raypak2100 heater, Pentair whisper flo 1.5, Hayward pool cleaner. TF 100 test kit.
    May 2013
    North East Ohio
    959
    Re: Estimating gallons
    The pool calc will help you out...
    http://www.poolcalculator.com/
    Go to the very bottom and you will get a solid estimate
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Use pool calculator and break it down into sections of the pool at the time.
    Wow, what a difference. Seems like it is about 9400 gallons, almost half of what I was told. sheesh.
    May 2013
    North East Ohio
    959
    Mmmm, I got quite a bit higher than that...close to 12K
    Hmmm....
    Do I figure out average depth by adding shallow +deep and divide by 2 or am I way off? I was never good at geometry
    May 2013
    North East Ohio
    959
    Is the wide section the deep end ?
    How deep is the jacuzzi ?
    Jacuzzi is 3.5 ft at deepest. 1.5 at the seat.
    7 ft diameter
    Pool is free-form. Measured in several areas the width. Widest point 14 ft. ave of the rest of the widths is 11ft.
