Results 1 to 7 of 7
Thread: Where is the best place for filter and pump
    Jun 2008
    North Carolina
    38
    I am having my AGP installed on Thursday. The ground slopes downward about 30 inches from high side to low side. Where is the best place to put the filter and pump? Thanks so much for the help. I can't wait until I know enough that I can post answers to other people's questions.
    Round 24' AGP
    13,500 gallons of cold water
    Sand filter
    BBB
    North Carolina
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Sounds like my neighbors yard. They put it on the low side, opposite the access point (ladder/deck area) as the pool installer will likely have to level your spot by digging down. So you are better off putting it on the low side, even tho it means walking around the pool to access the equipment.
    Try to retain access from either direction. Ours can only be accessed from walking all the way around one direction of the pool and I regret that layout now. Wouldn't mind adding stairs from our deck down to the filter/pump.
    Jun 2008
    North Carolina
    38
    middle or low?
    The guy who graded the yard today said we should put it in the middle of the slope. I'm new to pool ownership and so I'm not sure exactly how the pump and filter work so I don't know if it would be better to have them high or low. Thanks for the help!
    Round 24' AGP
    Sand filter
    BBB
    North Carolina
    It doesn't make too much difference as long as the pump and filter are below the water level. Choose a spot based on access to the equipment and overall appearance.
    Jun 2008
    North Carolina
    38
    Great! Thanks for the help!
    Round 24' AGP
    Sand filter
    BBB
    North Carolina
    Jan 2008
    Malaysia
    109
    I assume that you will be building your deck on the high end and hopefully towards your house. Then I would suggest mounting your equipment with the same level as your pool base on the lower end. But if your PB decide on the mid end, it's fine too but you'll need to construct a house for them like a cave. The walls can be from concrete blocks and a concrete slab on top which could even act as part of decking. This way, you'll not hear a sound from your pump. The nearer to the pool the better for maximum flow and pressure.
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
    May 2008
    Northwest Arkansas
    11
    I don't think it will make any difference as long as its out of sight and level. You will want to consider the humming noise a pump makes also.
    lartay
