Thread: Pool near trees and plants, anything to help?
    Hi,
    Can anyone give me advice about handling a pool that is placed attractively near the forest edge, with lots of plants etc. There is a constant stream of **** that gets in --- leaves, dirt, etc. It it only loses 1-1.5 ppm FC a day. When i run the pump and polaris after several hours the water is very clear. And later it isn't cloudy, still clear, but loaded with organic stuff. I thought about a net of some sort-but i'm sure it would look terrible. Just how much damage is the debris causing, other than eating chlorine?
    Thanks
    (attached is a picture after an acid wash)
    16,000 gallon, inground. Diamond bright finish. Hayward 1.5 hp superpump, quad 80 DE filter, Jandy legacy gas heater
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool near trees and plants, anything to help?
    I would say to make sure you have good skimming action and a good robot pool cleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Unless it's staying there long enough to stain, it's only consuming chlorine.
