Results 1 to 8 of 8
Thread: DE filter, pressure dropping
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Hi:
    This is a first. After I backwash/recharge my DE filter the pressure has always run, for years, between 10 - 11 psi as long as it's clean. But now I've noticed that it's been down to 8 the last couple of days. I've recharged it, cleaned the baskets, checked the weir, all is clear. The return feels normal and I do not see any air bubbles, I'm stumped.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    30,413
    Re: DE filter, pressure dropping
    Usually an indication of some type of restriction (partial blockage) on the suction side of your system.
    When the pump is running can you see air in the pot?
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Quote Originally Posted by keene3b07
    No, no air in the pot.
    10,800 gallons
    TF-100 Test Kit
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Don't see any obstruction from the skimmer to the pot. The pot, which is idle right now is filled with hazy water. Looks like DE????
    10,800 gallons
    TF-100 Test Kit
    38,262
    That could happen if you have a build-up of air in the filter that gets compressed. Then when the pump shuts off, the air pushes water backward through the filter into the pump.
    Another possibility regarding the lower pressure is that some debris is stuck in your impeller.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    I'm not familiar with the inner workings of a pool pump so I don't know if the problem is the impeller and everything "feels" normal. The pressure from the return, the suction at the weir. I cleaned, lubed and Teflon taped everything I could. Checked for debris, tightened everything and turned on the power. Wow, my pressure was back to normal and held for my morning cycle. But after the power cut, the pot once again was full of DE (?) and when the power returned, the pressure was the lowest it's been.
    So, while I'm waiting for someone to take a look at this, is there a downside? Should I run as normal?
    Thank you,
    Ed
    10,800 gallons
    TF-100 Test Kit
    May 2013
    Erie, PA
    53
    I'm curious to hear what you find out. This just happened to me as well. Pressure was always 15 since last year and this season. I bumped it and it started running at around 12. I also noticed de in the pool.
    Just took apart the filter and acid washed the fingers. Was expecting to find holes and tears but nothing. Everything looked good.
    Just put it back together and its running at 11, which at least now I expect it to do since I just cleaned it. Hoping I dont see any DE in the pool when I check it later.
    22,700 gallon, 18x36 Vinyl IG - Hayward EC65 Perflex DE Filter
