Results 1 to 11 of 11
Thread: Water Coming Out of Intex Sand Pump Basket - Now Not Working
    I just filled my pool, put 160 pounds of salt in it and can't get the pump to work. I turned it on for the first time and it looked like it was working fine, except that water was leaking out of the cover of the basket. I removed everything (possibly in the wrong order, had a lot of pressure when I was opening it - oops), tried to tighten things, made sure the rubber ring was in there and now, when I turn it on, it does nothing?! I've tried and tried, checked the manual, checked the valves going to and from the pool, checked the outlet, reset the plug, made sure I have the pump set to filter... Not sure what is going on here?! I'm doing this all by myself and feel so clueless.
    15 ft x 42 in Intex Easy Set Pool on a 20 ft x 20 ft Concrete Pad
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Water Coming Out of Intex Sand Pump Basket - Now Not Wor
    Did you open the valves to the pool? You wouldn't be the first to forget.
    Are those the tubes with the lock and unlock on them? If so, yes...
    I can't look at it right now, but I just realized I didn't recover the drain pipe after I back washed it. Could this be it?!
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by kristinainaustin
    If that's the drain on the bottom of the strainer basket, absolutely.
    Nope, not it. Is all of this correct? Other than the huge amount of water I've leaked everywhere trying to figure this out... I appreciate all of the help!
    Richard320's Avatar
    Jan 2010
    19,074
    I don't have that setup, so I can't say what goes where.
    Seems to me that gravity would fill the pump basket. Are you sure the gasket got installed properly? And when you say does nothing, does that mean no noise, either? Maybe all that water just made the GFI on the plug trip and you just need to reset it.
    If I switch it to backwash, water comes out without it even being on. When I put it on filter, then turn it on, nothing happens... No movement, no noise. Tried a reset, didn't work. I'm going to try adding more sand to it tomorrow. Not sure if that will help? I put a 50 pound bag in it, but saw that it needs 55 pounds. Thanks again! I really appreciate it!
    Richard320's Avatar
    Jan 2010
    19,074
    If the pump isn't making noise, it's not the filter's fault. Check that you didn't pop a circuit breaker or something simple.
    I think that was it. Its up and running now! Thanks!
    Richard320's Avatar
    Jan 2010
    19,074
    Look at the money you just saved on a service call!
    Now you can afford a test kit or a lifetime TFP membership.
