Results 1 to 7 of 7
Thread: Green water and low ph
    Hello I have a 24' round agp that was filled with a pool water delivery service two days ago. The water source was a well. I used the same service last year without problems. I use a swg for chlorine. Due to not having the proper salt level in the water I put one gallon of bleach in the pool last night and 3lbs of stabilizer. This morning i got up to put 360 lbs of pool salt in and the water was green but relatively clear. I did put one pack of aqua chem shock in as well which resulted in the high FC levels I guess. I don't think it's an algae outbreak but possibly metals after reading on tfp. I have read about sequestrants and other products but I am very new to pool chem. Here are my water results:
    15 FCC
    15TC
    0CC
    25 CYA
    80 TA
    60CH
    pH 6.8
    Due to the very low pH and high FC levels can I add metal sequestrant without problems? Also, should I use borax to raise the pH now or with until the FC lowers?
    Thanks for any advice you can give. I have a very eager 8 yo read to jump in.
    1) 20K gallons 2&5)Tagelus Sand Filter TA60D, 60 gallons/minute
    3inground 4)gunite
    6) installed 1984
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Green water and low ph
    If you got 6.8 pH with FC that high, your pH is actually much much lower. Check out how high FC affects the pH reading: accurate-ph-test-during-shock-levels-with-r-007-t61076.html
    Let the FC come down on its own until it's below 10 then recheck pH. As it is now, what you might be seeing is precipitation, which, if you can filter it out, will remove the iron completely. Check out these threads for some ideas. Or try the google search here waaaay down in the lower left. iron-problem-will-this-ever-end-t47144.html
    a-tale-of-two-filters-and-ugly-rusty-water-t46130.html
    [centeroiucybb][/centeroiucybb]
    Ok the water has improved in color and clarity, however, it still has a green tint to it. Any ideas why it still is green with a FC level of 2? My understanding was that it would improve once chlorine levels drop.
    Here are latest results:
    FC 2
    CC 0
    TC 2
    TA 80
    CYA 30
    CH 30
    pH 7.2
    3inground 4)gunite
    6) installed 1984
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by thanks82
    FC 2
    CC 0
    TC 2
    TA 80
    CYA 30
    CH 30
    pH 7.2
    That's still metal in the water. Pale orangish rusty water will look blue with the blue pool walls. I think it's time to re-read pool-school/metal%20stains and shop for some sequestrant.
    Thanks for the quick reply. I added one bottle of sequestrant. I also have some ferri tabs that are supposed to arrive tomorrow. If I add more sequestrant will that prevent the ferri tabs from being effective?
    3inground 4)gunite
    6) installed 1984
    Richard320's Avatar
    Jan 2010
    18,967
    I have no idea. There is another thread where someone will be testing them, ferri-tabs-experiment-review-t62508.html
    Hold off on them and see what he gets.
    Yesterday I received a Culator in the mail that I had ordered to try for the iron problem. I put it in the skimmer as instructed last night and today the water is crystal clear. So glad to finally have water that is not green. I'll keep the ferri tabs for when I have to replenish and see how they do.
    3inground 4)gunite
    6) installed 1984
