Results 1 to 8 of 8
Thread: Stains on steps
    Stains on steps
    I have finally got my pool crystal clear using the BBB method. I am very happy. However I have brown stains on my steps. I am not sure what they are from, but they weren't there when I closed the pool. I have tried a scrub brush and magic eraser. Neither seem to work. Any suggestions. I have a beautiful pool with ugly steps. Please help.
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I recall reading on here if you have any pucks, rub one on the stain and see if it disappears, then you know its organic. There is also a way to tell if it's a metal stain. IF it's a metal stain it won't disappear when rubbed....
    Did you do a search for metal stains?
    Mar 2007
    Coastalish 'down easter'
    4,160
    To check for metal stains, simply rub some pure ascorbic acid (Vit C) on the effected area and see if the stain lessens - if so, it's metal and we can help you deal with it -- or you could just keep rubbing vitamin C on all the stains.
    Luv& Luk
    -Ted
    11,969
    Quote Originally Posted by waste
    Thats it! Vitamin C.... I knew you experts would be along shortly....
    I finally got the vitamin C and rubbed it on my steps. It seems to remove the stain. Now what do I do. There is too much to keep rubbing with vitamin C is there another way to get rid of know that I know that vitamin C will take it off. Thanks for all your help
    Don
    SW Florida
    Pentair SWG
    Guest
    Read this sticky. It will explain it all.
    Thanks so much great information. One more question what is sequestering agent?
    Don
    SW Florida
    Pentair SWG
    Guest
    It is a 'metal remover' like Jack's Magic, Proteam Metal Magic, Sequasol, etc. You get it at the pool store. I would stay away from Naturalchemistry's MetalFree (or other metal removers that do not add phosphates--the main ingredient will be EDTA) because they are not as effective. The ingredient you want in the product will be HEDP or phosphonic acid or a phosphonic acid derivative.
