Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: First Time and Jumping In
    Hi All,
    I've been reading and reading and reading and **think** I have a grasp on where I'm going, but want to do a sanity check.
    I've got a 12000 gallon SWG pool, using the Jandy Aqua Pure. Current temp is 86 degrees. The pool is in partial sun all day and clean of most leaves/organic material. I've had a pool guy for a couple of years, but have decided to take the plunge and try to do this myself.
    Currently my pool is slightly greenish. Enough to be noticeable, but not enough to keep anyone from wanting to jump in.
    I've got the testing kit and have the following results:
    FC 1
    TC 2
    PH 7.8
    TA 50
    CH 200 (to purplish, 220-240 to my idea of blue)
    CYA - less than 30. I can still see the dot, but it is hazy when it's full
    I'm thinking, that my next step (according to the pool calculator) is 5 lb. of stabilizer/CYA to get to 70 and 181 oz. of 8.25% (what I have) bleach to go to a goal of 11 on the FC shock the pool.
    I'm looking for a sanity check. Does this sound right?
    Thanks for your help!
    Lynn
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First Time and Jumping In
    You don't need to get the CYA that high. You'll just need more bleach. Get it to 30 for the process. Lower your ph to 7.2.
    Jeff
    Thanks for the quick reply. I'll do that.
    I got the CYA off of this chart. I'm guessing that I don't understand what I'm looking at?
    pool-school/chlorine_cya_chart_shock
    SWG
    Jandy AquaPure 1400
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Welcome!
    Assume CYA is 20ish and raise it 10 ppm, then commence the shock process using 13 as your target FC level. Keep adding bleach every couple hours to keep it at 13 until that green goes away. More complete instructions are in pool-school/shocking_your_pool
    Once it's clear and sparkly, then raise CYA to 70 and let the SWG take over. A few weeks of testing and adjusting and it will all make sense and you will have a clean sparkly pool for the rest of the summer.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That's fine for when your done with the shock process.
    Jeff
    Got it. Thanks so much for explaining. I'm glad I asked before dumping all of that stabilizer in!
    Salinity is a little low too - 2.6 and it should be 3.0-3.5. Should I wait until after the shock to add salt?
    SWG
    Jandy AquaPure 1400
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by LynnOnTheWeb
    Look at the difference in shock level between 30 and 70. If you want to buy and carry a few dozen extra gallons of bleach, take it all the way up in one shot. I wouldn't.
    The SWG is sort of out of the loop during the shock process. Worry about salt after.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would. You can turn SWG off till your done with the shock process
    Jeff
    Thanks for the info. I'll make these adjustments and turn off the SWG until all is well.
    SWG
    Jandy AquaPure 1400
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job !!
    Jeff
    Okay, pool looking good. I upped the chlorine to 13 (maybe? my test doesn't go that high) and this a.m. it was back at 1. Increased it again this a.m. and tested about an hour ago and it's at 5. I'll test once more in a couple of hours and add more bleach if needed.
    Stabilizer put in sock in filter basket. Will retest next Sunday to see if the levels are better. Adding MA tonight to get the PH down per pwrstrk's advice.
    I know next steps are to let the SWG take over. That said, should I continue managing chlorine via bleach for the week, until I know my CYA is up? And while waiting, should I be focused on getting my other levels to the ones listed here:
    pool-school/water_balance_saltwater_generator
    Or, should I try to let SWG tak start taking over now?
    Thanks again for your advice on this. Waking up to a pool that had less green than the night before is totally giving me confidence (and maybe a little cockiness)!
    Edit: Went and retested everything. PH dropped to 7.2 on its own.
    SWG
    Jandy AquaPure 1400
    Jun 2013
    Hartland, MI
    67
    From what I've read adding cya will lower your ph.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Richard320's Avatar
    Jan 2010
    18,995
    You can use the SWG to help maintain FC levels between bleach doses, but it won't be able to do it alone.
    Is the pool clear? That's the first test to know when the process is nearing completion. If it's still cloudy, you need to keep hammering it with bleach.
    Just treat it as a bleach pool with CYA of 30 until it's sparkling and passes the three tests. Then you worry about raising CYA and adjusting things to SWG recommendations.
    Yes, the pool is clear. I'll keep on keepin' on with the bleach until CYA is up.
    Thanks!
    SWG
    Jandy AquaPure 1400
    May 2013
    Bay City, Michigan
    283
    If you've payed a pool guy for a few years, a good test kit should be an easy cost to swallow. You will really need it to know when your done shocking. No other way to read shock levels and perform the OCLT test for shock process. It is your best tool for clean healthy water/pool.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    If your test won't go up to 13 then you need a FAS-DPD test to add to what you have or a new test kit.
    The process requires a high precision test that can measure at shock levels and give repeatable results with at least 0.5ppm accuracy and precision.
    Sent via Tapatalk...
    May 2013
    Bay City, Michigan
    283
    you can buy an entire kit or you can buy just the FAS/DPD chlorine test.
    http://tftestkits.net/splash-page.html
    http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    This is the kit I have.
    http://www.lesliespool.com/Home/Pool-Ch ... 81330.html
    Should I just add the FAS/DPD or is there something else that needs to be added to my arsenal to make this complete? I'd like to order everything I need now so I have it when I need it.
    SWG
    Jandy AquaPure 1400
    Richard320's Avatar
    Jan 2010
    18,995
    The FAS-DPD will make it a K-2006.
    Check your other reagents. The kit you have is sort of skimpy on things, especially the CYA test.
    If you're in a shopping mood, get a speedstir. You won;t regret it.
  20. Back To Top    #20
    May 2013
    Bay City, Michigan
    283
    take into consideration the age, would hate to see you just add the FAS/DPD then have to order more replacements or a hole kit after cause of old reagents and pay shipping twice.
