Thread: Pool not up but can't I go ahead & test water with TF kit ?
    Jul 2010
    Raleigh, NC
    60
    TF100 kit arrived. Pool is still in box (leveling about to begin).
    Any reason I can't go ahead & test water? Instead of going to buy a white 5 gallon bucket, can I test water some other way?
    It's city water by the way.....
    Karen
    26' x 52" Intex Ultra Frame (14,667 gallons), Hayward Matrix 1hp 2speed, Hayward ProSeries 21" sand filter
    1.5" PVC piping with in-wall skimmer, TF100 test kit
    City water in Raleigh, NC
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool not up but can't I go ahead & test water with TF ki
    Sure. Go ahead and test. It'll be good practice.
    Jeff
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just don't bother with the CYA test since there will be none. Otherwise it is always good to know the numbers from your fill water, particularly the pH and the CH
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Why do you need a bucket? You can run all the tests with about a cup of water.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    I bought a gal. bucket when I first got my pool. I have never used it LOL
    I just put my water in a small plastic bottle that is easy to pour into the test tubes.
    It is a good idea to "play" with your test kit to get a good feel for it. Plus it is just plain fun!
    Have fun!
