Thread: Rectangle pool , concrete free form decking?
    Thoughts on this? We are supposed to start digging June 24. IG vinyl, 20 X 40, saltwater with auto cover. Live in NE Ohio. We are still deciding the liner and amt of decking (some type of concrete). I keep getting the runaround on whether or not stamped concrete is too slippery. Super important as I have a son with autism who doesn't always listen. Pavers aren't in the budget. Thoughts? I am thinking perhaps a colored concrete with a different colored concrete coping? I thought about flagstone for the coping but am worried about the saltwater with it.
    Amy
    36K gal (40 X 20), IG vinyl w/AC, Hayward single speed Super Pump 1hp, Hayward C1200 Star-Clear Plus 120 sq ft cartridge filter, Hayward AquaPlus SWG
    TF-100 Test Kit, Dolphin Supreme robot
    Cleveland, OH
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    Re: Rectangle pool , concrete free form decking?
    Stamped sealed concrete is slippery unless you use a sealer with grit in it from what I hear. I am in the process of negotiating a contract and I am thinking stamped concrete.
    Pool: IG, 8'W x20'L x5' deep, 6000 gallons, Stonescapes Blue Tropics Mini-Pebble gunite pool
    Equipment: Hayward SwimClear 3030 cartridge filter, SP32102EE Tristar 1 HP 2-speed pump,
    Universal H-Series Low NOx H400FDN (400K BTU) heater, SWG = Hayward Aqua
    Rite with Turbo Cell 9, and a Navigator XL cleaner
    Ground break 7/12/2013 Filled 8/6/2013
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    My understanding of flagstone in this area (usually PA Bluestone) is that it is much harder than the Oklahoma flagstone that many on this site refer to. I have not heard of much/any issues with PA Bluestone and saltwater. I can't attest yet, but in a few years I'll let you know! With this part of the country receiving regular rainfall (most years) the accumulated salt from splash-out gets washed off pretty regularly too which is also a positive. Our concrete is stained then sealed. It is moderately slippery. They sealed it shortly after staining (in May) because it was new but recommended I seal it annually in the fall to give the best protection from freezing and also to allow the sealer to be on it's less slippery side during the following swim season. Was just at a pool this weekend with new brushed concrete (not stamped or stained) which was very slip-resistant. They had irregular stone "grout lines" brushed in with a tool of some kind during installation to tie it somewhat into an existing older stamped patio. I liked that look on concrete and is what we had also given some thought to.
    Our pool is rectangular with a large rectangular deck so the kids can be kids and the adults aren't getting in the way too much. It's also separated from the house so we have no benefit of a companion paved surface.
    Good luck with your decisions and the process!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Can I ask how much decking around your pool? I'm actually thinking brushed concrete at this point. On ours, one end will be 8 ft with diving board. Ours will also be a slight walk out to the pool. There will be 3-4 deck jets, so I was thinking 5 ft on that side, 8 ft on the opposite side, then the ends. I would think the end with the diving board would need a minimum amt for clearance. We had this all designed out, but have changed our mind which changes the ENTIRE landscape. Ughh. We have full sun and need a place for shade. So I'm wanting to do a composite deck that is at least partially covered to offer shade. Eventually in the plan was a ramada with possible small bath (going to get it plumbed and electric b/c you never know, we MIGHT win the lotto).
    Cleveland, OH
    Also any pics of yours bmoreswim?
    Cleveland, OH
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    I see you've found the pictures through my signature link and I've replied back over there as well to keep the A's with the Q's. The diving board end has 8' (a shed/changing room structure will extend off of this end some day). The house/upper side has 14'. The end opposite the diving board is 15' (future 10' x 20' pavilion - for which three footers are poured integrally with the deck, as we have full sun as well). The lower side has 4'. All not counting the 1' coping.
    I recommend modifying your forum title somewhat and documenting your build here. You can start with the before pics and specs any day! You'll no doubt get helpful suggestions along the way as I have. The information I've received from this forum on the pool subject is priceless.
