Thread: Summertime CYA
    kkendall's Avatar
    Phoenix
    67
    Summertime CYA
    Should CYA be brought up a little higher in the summer vs winter level?
    Mine is at 30
    I noticed about a week ago a slight odor of chlorine. Up to then, it was hard to telll there was any chlorine in the pool at all (CC has alwasy been 0). So I tested and noticed CC was at .5.
    Brought the chlorine up some and tested overnight. FC loss was .5, and CC was now at 1
    Added a couple gallons and drove FC up to 15. Throughout the day, I tested every couple hours and saw FC drop like a rock, but CC came back to .5. By the end of the day, FC was at 5 - CC still .5
    Made me think, the best time to shock is overnight. Also made me question my CYA level being too low for the summer here in Phx.
    * 18.5 K Gallon, 8ft deep, IG, Pebble Radiance * Pentair VS 3050 Pump w/420 Cartridge Filter
    * Blue Square Q-360 In-floor Cleaning System * UltraPure UPP25 Ozone Generator
    * Pool startup: 09-04-2012 * TF-100 Test Kit
    Re: Summertime CYA
    Yes, in Phoenix you certainly want CYA above 30. I recommend 50 to 60.
    kkendall's Avatar
    Phoenix
    67
    Re: Summertime CYA
    I see some folks use granular stabilizer to raise CYA. I've been thinking of just using trichlor tabs until CYA is where I want.
    Opinions? Does it really matter?
    Feb 2008
    Denton, TX
    5,061
    Re: Summertime CYA
    Quote Originally Posted by kkendall
    No, not really. Tablets will add CYA much more slowly. You can use them to both chlorinate and raise the CYA. Just remember to keep checking your CYA along the way to make sure that you don't over do it.
    30,424
    Re: Summertime CYA
    managed carefully, the tabs are ok. Probably easier and more predictable to dose one time with granular.
