Thread: No bubbles coming from the floor of pool
    Hi and thanks for any help! I cleaned my cartridge filters yesterday. After reassembling and turning the pool back on I'm not seeing any bubbles on the floor of the pool. these would previously be there when i turned the pool back on. the pump seems to be running. The pressure is back to normal. Any ideas what I should check? thanks again.
    Laura
    Baltimore MD
    IG pool 25,000 gallons
    Cartridge filter
    Plaster pool
    30,408
    Re: No bubbles coming from the floor of pool
    What opening do you have on the pool floor that was releasing bubbles?
    I believe where the bubbles used to come up was at the main drain. I would normally see them when I turned the electric back on. this time...no bubbles. the water is moving through the skimmers just fine...so maybe there is nothing to worry about. I'm new to this and really just trying my best to make sure nothing is wrong. thank you for taking the time to reply.
    Laura
    Baltimore MD
    Cartridge filter
    Plaster pool
    30,408
    If it was coming from the main drain, that's a little bit unusual but certainly nothing to worry about.
