Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: What would cause phosfloc not to fall to the bottom
    what would cause phosfloc not to fall to the bottom of the pool? and how to remove it if it doesn't?
    monroe,la
    size 22000
    saltwater
    hayward sand filter 300
    aquarite 40000 gen
    Re: What would cause phosfloc not to fall to the bottom
    The most obvious possibility would be leaving the pump running. You need to have the pump off for at least 8 hours, preferably more, (after running the pump to get the Phos Floc mixed in) for everything to settle.
    Phos Floc can also cause secondary clouding, where the Phos Floc does settle to the bottom but there is some additional clouding beyond what settles to the bottom.
    By the by, we don't recommend ever using Phos Floc. Phosphates are harmless if you maintain appropriate FC levels. Phosphate removers are a waste of time and money, and frequently cause problems like cloudy water.
    30,421
    flocculants are unpredictable it seems and that unpredictability is why we virtually never suggest using them. How does your water look? Why did you use the floc?
    the pool store where i have my water tested recommended using it because i had high phosphates. i wish i had found this site first. my water was in range.so they said, it is a 20,000 gal sw pool. i had a metal stain problem and used a stain remover and followed up with a metal magic. after that my water became cloudy. i could see the bottom on shallow end and on the deep end i could almost see the bottom. i had also recently changed my hayward filter sand using quickrete pool sand.i backwash the filter until clear. i put the phosfloc in and circ bypassing the filter for three hrs. it has been 24 hrs and the pool is still milky . any ideas? thanks for responding.
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
    My main recommendation is to stop listening to what the pool store says. They make money selling you products and you get a cloudy pool
    Please post a complete set of water test results. It is nearly impossible to diagnose issues like this one without knowing the levels.
    Your filter should clear up the cloudiness, but it may take a while. What kind of filter do you have (sand, cartridge, DE)?
    Some cloudiness for a few days after using stain remover is normal. However getting algae in that situation is also common, so there are at least three possible sources of cloudiness (stain remover, phos floc, algae).
    30,421
    any ideas?
    Stay out of that pool store...they are not helping you. Take charge of your pool water management by purchasing a very good test kit that will save you money and teach you what you need to know. That "free" testing you are getting at the pool store is worth exactly what you are paying for it.
    Jenischmeni's Avatar
    May 2013
    Indiana
    91
    Mind what these people say, because they're right. I spent a summer foolishly fighting phosphates. The amount of money that I spent in one summer was ridiculous and I'm too ashamed to even say how much money that was.
    The pool stores bamboozled me and had me convinced that if I didn't clear out those phosphates, I would have a swamp with frogs living in it. I was on the floc / clarifying roller coaster. I'd add the floculant and then have to add these tablets to clear the water from white back to blue.
    Eventually, I ended up draining the pool and refilling. Guess what? I still had phosphates. (Yes, I had tested tap water before filling and the tap water had none.)
    I had to give up on the battle because I just didn't have any more money to throw at it. Little did I know that was the smartest thing I could have done.
    If I could go back to that summer, I'd tell myself to spend all that money on a mini-vacation for hubby and myself!
    Central Indiana, 7200 gallon, IG fiberglass, L250 Jacuzzi sand filter, Hayward H150 gas heater, Pentair fiber optic light - installed '06. AOSmith 1.0hp pump, CPSC-24 SWG - installed '13. TF-100 Test Kit.
    right now my pump is off due to trying to get phosfloc to settle to bottom. man i wish i hadn't put that **** in my pool! anyway, my chlorine is not there because i've had my pump down .ph 7.2 ak 100 . do i need to keep trying to get it to settle or start my pump to try to filter it out?
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
    That depends on how long it has been. If you have already waited 24 hours, then give up and get the pump running. But if it hasn't been 24 hours since you turned off the pump, give it some more time, it might yet settle.
    yes, it's been over 24 hours i've put the pump back on . i guess i will try to filter it out. do i need to shock or anything?
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
    lee872's Avatar
    Central Massachusetts
    59
    I flocked last year before I found this site. It took 48 hours for the flock to settle so I could vacuum it out. My pool often takes 2x as long to do what it should --- don't know why, but patience works.
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    what would be the best test kit to buy for my salt water pool? and i just want to say happy fathers day to all the dads.
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
    Mar 2007
    San Rafael, CA USA
    12,082
    For any residential pool, the TFTestkits TF-100 (or the Taylor K-2006 though the TF-100 is more economical with more volume of reagents you use the most -- see Test Kits Compared for a comparison). Having a saltwater chlorine generator pools doesn't change the type of test kit you get except that you can additionally get the Taylor K-1766 Salt Test or the AquaChek Salt Test Strips.
    thanks for the testing info. i started my pool to filtering last night before i went to work. it's been filtering about 14 hours. don't seem to be clearing up. do you think that just filtering by itself will get the phosfloc out?
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
    what about using sink and sweep to make the phos floc fall.
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
    kdubya815's Avatar
    May 2009
    Columbia, TN
    123
    Sand filters take a little longer to clear up cloudy water. I would continue to filter 24/7 until it is clear. I think if you keep throwing the floc/clarifying products at your pool, you are just lengthening your fight. It can be very hard to give up the mentality of pool store advice (keep throwing stuff in until something works!) even if you are not seeking the advice of the pool store anymore. Keep your water levels in range using poolcalculator.com and take total control of your pool! A good test kit is the best investment you will make for your pool. I have the TF100 and it tells me everything I need to know!
    I am by no means an expert, so if someone else comes along and disputes my advice, listen to them! However, I can tell you that after finding this site around 4 years ago, and following the methods taught here, I do not go to the pool store and buy all the wonderful products they sell. I know how to maintain my pool, I am very comfortable with my family swimming in a pool that I know is properly sanitized, and I have beautiful water! You will find countless stories of people who can share the exact same experience as me. It works. You just have to trust it and you will see amazing results!
    18x36 Grecian style vinyl 23,000 gal inground pool, Hayward Pro Series S220T sand filter, Hayward Super Pump 1 hp.
    kdubya815's Avatar
    May 2009
    Columbia, TN
    123
    You can also you a skimmer sock (aka knee high) on your skimmer basket to help filter out the cloudy. It will catch a whole lot, so make sure you check it every couple of hours at first so you can rinse it off.
    30,421
    Great post, KW
    thanks. where do i get skimmer socks?
    monroe,la
    size 22000
    saltwater
    aquarite 40000 gen
  20. Back To Top    #20
    kdubya815's Avatar
    May 2009
    Columbia, TN
    123
    Great post, KW
    Thanks Duraleigh! Yay!!
    Quote Originally Posted by gabby
    I just use women's knee highs. They are a lot cheaper than commercially marketed skimmer socks, but they do the same job. I wrap the top around the skimmer basket and push the foot through to the bottom of the basket. Once I see it is dirty, I wash it off with the garden hose and put it back in. Very easy but effective!
