Thread: Which pump for new AGP?
    May 2013
    Santa Barbara, CA
    10
    Hi,
    I'm in the process of installing a 15x30 AGP and would like your opinion on which pump I should get. The choices (for now) are:
    - 3/4 HP 2 speed Pentair Dynamo 120V (8amps high/ 2.6 low)
    - 1 HP 2 speed Pentair Superflo 220V (6.0 amps high/2.3 low)
    I'm planning on a larger sand filter (Pentair SD80), and to run solar heating at ground level (not sure how many panels yet).
    Will the smaller pump have the power to run the filter and solar at low speed? Is the dynamo louder than the superflo?
    Any advice will be greatly appreciated, thanks!
    15x30 Sharkline Heritage AGP, 8000 gal
    Pentair SD80 Sand Filter, Pentair 2 speed .75 HP pump
    Self-built July 2013
    BBB (Just bleach) so far
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Which pump for new AGP?
    I would stick with an AG pump. The Dynamo will have plenty of flow rate for the filter on low speed. As for noise, I think they are probably close to equal.
    Mark
    May 2013
    Santa Barbara, CA
    10
    It looks like I'll be getting the 115V pump, as the circuit I was going to use for power (currently 240V electric dryer) does not have a ground line, so don't think it would work with GFCI.
    Thanks for your help on this!
