Results 1 to 10 of 10
Thread: Partial drain on above ground pool
    Ok, I have a 16 x 32 vinyl above ground with a deep end of 5ft. I have had my pool 13 years. 1st 6 yrs I used baquacil. Had a lot of problems with water mold and pink slime so I switched to bioguard. Been on chlorine for 7 yrs now. I have a chlorine demand and after spending $400.00 dollars so far on pucks, diclor, triclor I still have no free chlorine reading. Test are showing cya up over 150. Pool store are not concerned they just want me to keep addin more shock. I have added 20 Lbs shock so far and still have not beat the demand. I am fed up of pool stores. My pool is clear but I don't like not having free chlorine reading. So after all this.... How do I do a partial drain on my above ground vinyl pool. My goal is to get the cya down to 40-60 and never use pucks, dichlor, triclor again. Is it safe to just vacuum to waste until it is half full and then fill it up again.
    30,427
    Re: Partial drain on above ground pool
    Yes. You may have to do that twice to get CYA down to manageable. Don't drain it all, just do it in 50% increments.
    You need to RUN from that pool store and commit yourself to a really good test kit and manage your own water......you'll never look back.
    Partial drain has started. The test kits I have are aquachek 7 test strips and the Taylor K2006 complete Fas-dpd chlorine. Can you recommend better test?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Quote Originally Posted by tarab
    K2006 is a good one. Toss the strips.
    And Welcome!
    30,427
    Go get the strips you tossed and toss them even FURTHER!
    Trust your K2006...it's a good one.
    Apr 2012
    SW Ohio
    456
    Ditto
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Got a little nervous, pool water was down to 26 1/2 inches deep, a few wrinkles started to show up. Not sure if they were there before or not. Starting to refill now. Will test after refill. How long should I let the water circulate prior to retesting cya?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    A good hour should be plenty to mix in the new water.
    Casey's Avatar
    SW PA
    10,453
    If you go for another drain/refill, leave a ft or more of water in the shallow end.
    Ok, I refilled pool. Let water circulate for 1 hr. I tested ph it showed 7.2. I tested free chlorine in showed 0.0. Alkalinity was 250. It took 25 drops to turn red. I tested cya and it showed to be 50. I tried using the pool calculator and it showed adding 400oz. of 10% chlorine. I added the chlorine and will retest in the a.m. My taylor test kit is 2 yrs old. I probably need to buy some new. I am still learning so please have patience. I may ask a lot of questions. If in the a.m. I still have free chlorine, I need to figure out how much to add daily as a maintence dose.
