Thread: Got Duped On A Hose?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Bought a swimline 100ft backwash hose on eBay. I've never had a backwash hose before but this is definitely not what I thought it would be like. The ad called it "heavy duty" and this is a cheap, translucent plastic sheath! I couldn't even get it on the pipe (correct size) without getting it all ripped up. I already created a claim to return it on ebay, but take a look at it. This thing wouldn't have lasted past one backwash, if that, right??
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    38,463
    Re: Got Duped On A Hose?
    That certainly looks thinner than the ones I have usually seen.
    4knights's Avatar
    NE Kansas
    419
    Go to your local hardware store or rental place, ask if they ever sell thier used pump hoses.
    I bought a 50ft long, 2 inch hose that has the threaded ends for $20.00 at my local Water's True Value Rental desk.
    The guy said he had about 25 hoses of different size and lengths in the back that they have had for years. I got my pick of the bunch. Went home and glued a PVC threaded male collar on my waste pipe. No issues with needing to clamp it or worry about it staying on.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    As long as there are no kinks, the backwash hose has very little pressure on it.
    I bought a vinyl one at Lowes. It feels sturdy, but I assure you, they can pop if they aren't rolled out completely smooth.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You can also buy old out of certification date fire hoses on ebay, typically you can find 50-75 ft hoses in the $30-$40 range, many times these were in fire cabinets and never used.
    Ike
