Thread: Question on refilling pool
    NE Ohio
    63
    I had to put a new liner in my pool (boy was that a project!) I was wondering if I have to shock my pool if it is not green? I know I need to add cya and bleach to bring my chlorine up, but if it is clear I should not have to shock do I?
    Thanks!
    24" Round Above Ground 52" high
    Jacuzzi CFR 100 Platinum Filter
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Question on refilling pool
    If you have a test kit with FAS-DPD chlorine test you can run an over night chlorine loss test. That test is most accurate at shock levels but is ok to run at non-shock levels for a quick test.
    The longer the pool water sat without chlorine the more you are at risk for something growing.
    Sent via Tapatalk...
    NE Ohio
    63
    Quote Originally Posted by UnderWaterVanya
    I just filled it up overnight with city water. I do have the test kit recommended on here, so I guess I will bring my chlorine levels up, and then test them over night after I get some CYA in the pool.
    Thansk!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    With a new, clean liner and city water, I wouldn't bother with the shock process. Just keep close watch on FC, because it will disappear fast without the CYA sunscreen effect.
