Thread: Water Balance
    Oct 2011
    Chicago, IL
    113
    Water Balance
    Hello all, finally got my pool up and running. To give you all background on pool, vinyl liner was just installed so the water is all new. Im in the process of adding stabilizer to raise CYA. My SWG is broken and I will be replacing next week so manually adding liquid bleach until then. Here are my levels:
    TC- 1
    TA - 90
    CH - 190
    PH - 7.2-7.5
    I will be adding the liquid chorine to maintain TC, but wondering if any of my other levels need to be adjusted?
    I have a 35,000 gallon, sand filter, sunken above ground (so inground), vinyl liner, with an Aqua rite turbo cell SWG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Water Balance
    You look good to go! Keep your FC matched to the level of CYA you have added per chlorine/cya chart in pool school.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Water Balance
    What he said ^^^
    CYA, bleach, swim.
    The CYA just hanging in the sock won't bother anyone, just don't let the kids get too rambunctious with it. It's okay to swim with the sock dangling there.
    38,305
    Re: Water Balance
    My kids quite enjoyed playing with the "diamonds" in the water when I just added salt to my pool. The solar salt works better for this and is cheaper than the pool salt.
    Oct 2011
    Chicago, IL
    113
    Re: Water Balance
    Thanks guys, very helpful. I'm staying on top of it and my water is crystal clear!
