Thread: vacuuming does and don't
    Jun 2013
    Up in the mountain, Laurentides, Quebec, CANADA
    23
    Hi,
    I didn't find a section about vacuuming does and don't in the pool school.
    I am wondering when you need to vacuum in draining mode versus filter mode. This is my first season with a pool and from now on I was vacuuming only in drain mode but I realised I'maybe loosing too much precious chemicals doing so. On the other hand I don't want to clog my sand filter... What are your advices regarding this matter?
    24.5k gallons, IG, vinyl, 24 inches sand filter hydropro 063030 sf, hayward pump 1,5 hp c48m2n111b4q
    Jun 2012
    Louisville, KY
    266
    Re: vacuuming does and don't
    Normally vacuum in filter mode. If the is a lot of debris then vacuum to waste. Best to get up what you can with a leaf net first then vacuum. Vacuum is for fine stuff you can't get with a net.
    Leaf net first, then Vacuum.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    When you vacuum to filter, you can always still backwash if need be. I only ever vacuum to waste if I have the extra water from rain I need to lower the level on.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I manage just fine without even having the option of vacuuming to waste. No multiport on my setup.
    If you're trying to suck up a compost pile in a green sludge pond, then vacuuming to waste makes sense. But for a well-maintained pool with regular cleaning, you'll mostly just need to empty the leaves and acorns and whatever out of the basket.
    Jun 2013
    23
    Ok great. Thank you!
