Results 1 to 9 of 9
Thread: Waiting a week to test CYA ?
    May 2013
    Long Island NY
    419
    As soon as the granular CYA dissolves from the sock can I do the test or do I need to wait a week?
    It would seem to me that if it has completely dissolved than it's in the water and would be ok to run the test, right?
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    38,290
    Re: Waiting a week to test CYA ?
    Just because it is out of the sock, does not mean that the dissolving is done ... I think there is still a chemical transformation that takes some time.
    What is the hurry to test? Just assume it is at your target level.
    May 2013
    Long Island NY
    419
    I know I sound like I'm in a hurry but my cya is at 10 and I'm going through the bleach faster than I think I should.
    I put in almost a gal. At night and the next night it's gone. No swimmers , today was the first day it got to 80 and I keep it clean. Pump runs 8 hrs a day.
    I just think my cya is to low and the bleach just doesn't last, heck when I do the test , no color at all, clear as it can be.
    Also my water is Gin clear the best it's ever been.
    There's nothing wrong with my testing because a couple hrs after the bleach has been added she test fine.( I did that as a check)
    How much CYA did you add? It sounds like you didn't add nearly enough, but there are some other possibilities.
    May 2013
    Long Island NY
    419
    Jason, I have about 20 3" pucks left from last year. I have 3 in the clorinator now.
    The funny thing is I started the yr with cya @120 , drained 2/3 and was fine.
    Then we had 3 big rain storms with one raining 4 in. So I was constantly taking more water out.
    Now I'm at 10 and to low. Also last week I used stain free to lift some stains and before I did that I let the chlorine drop to O. Then treated the pool , stains gone and now just to low cya.
    I also use an algacide when I lower the chlorine for the stain free.
    38,290
    So did you add any CYA or not? Besides the pucks.
    May 2013
    Long Island NY
    419
    No I have not added any granular. 3 puck in there now that are about gone.
    Then your CYA level is somewhere around 10, maybe a bit lower. The CYA test won't measure levels that low. Also, there is no need to wait a week to test unless you added granular CYA. Liquid stabilizer, dichlor, and trichlor all register on the CYA test within an hour or two.
    May 2013
    Long Island NY
    419
    Ok thanks Jason , I guess I will go out and buy some stabilizer, those 3 " pucks will take to long to bring my cya up to where it should be.
    I will save those for vacation
