Results 1 to 9 of 9
Thread: Big thanks to TFP
    Big thanks to TFP
    Hello all, I am a proud owner of a 27' round crystal clear trouble free pool thanks only to this site. I only wish I would have found this site prior to purchasing my pool from a store, live and learn. Thankfully I did join prior to the install, which was a nightmare, so I have not stepped back into the PS since. I purchased my TF-100 kit about a month before install and checked a hotels pool to get some practice in. The install was BS, the store used a sub contractor that took care of there customers first. After many angry calls I finally got the pool in and up. They wanted to send a crew over at 6:30pm, after a long day of installs, to finish mine. I would not allow it and told them that my village does not allow any construction after 7pm. I have not posted prior to today because I Have found all my questions answerd just by using the search here. So thank you very much .
    24' round AGP 17Kgal. TF 100, BBB method all the way
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Big thanks to TFP
    Welcome to tfp, daa1275
    Other than the install hassles, it sound like you are getting off to a good start
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Love that
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Welcome!
    here is a few pic, the ladder in I had to build couldn't find a proper one
    attachment=0]picture007.jpg[/attachment][attachment=0:1lh8p38o]picture011.jpg[/attachment:1lh8p38o]
    Feb 2008
    Denton, TX
    5,061
    Great job on those stairs!
    We didn't pay attention to the entry stairs when we bought the pool. We did tell the salesperson that we needed sturdy stairs for our rather LARGE family, but the ones we got bent with a child on them. I called the PS and our wonderful sales person told us that they didn't have a more sturdy step unless we wanted to purchase a deck from them. I am not a carpenter at all. Thankfully Menards sells treated pre cut stringers or I would have failed. The water condition has been going good due to this site. My test today was
    FC 2.5
    PH 7.5
    CC 0
    CYA 40
    CH 110
    TA 230
    Butterfly's Avatar
    South Carolina
    10,045
    FC 2.5
    With 40 CYA, maintain FC between 3 and 7, and never below 3.
    I should have mentioned that I did bump the FC to 5.5 prior to swimming.
