Thread: Please review our new IGP build
    About to pull the trigger and would really like some opinions about the bid we have narrowed it down to. Thanks in advance.
    General Specifications
    Pool Style Custom Design
    Pool Size 26 x 32
    Total Area 644 Sq Ft
    Depth Range 3.5 x 5 x 4
    Structural
    Excavation Bobcat Dig
    Steel Schedule 8 on center w/Alternates @ 4 on center in deep end
    Pool Structure 4500 psi gunite/ 6.5 sack mix
    Walls 6 minimum thickness
    Floor - 6 minimum thickness
    Bond Beam - 12 minimum thickness box beam 4 bars of #4
    Equipment
    Pentair 420 cartridge filter
    Pentair whisper-Flo 2Hp
    Pentair legend with booster pump grey
    Pentair whisper-Flo 2Hp for water feature
    400,000 Btu Pentair master temp natural gas
    Easy Touch system 8 pool/spa with IC 40 salt
    2 LED
    1 LED for spa
    1.5 HP silencer air blower with switch for spa
    6 anti-entrapment safety drain VGB complaint
    2 with leaf basket & tan PVC cover
    7 directional returns for maximum circulation
    Plumbing
    Hydraulic designs Separate lines for all skimmers & main drains
    Pipe All 2 schedule 40 PVC
    Valves Pentair Never Lube 2 x 2.5
    Fill Line pool fill line
    Overflow Line Included tied into deck drainage system
    Backwash line to sewer cleanout if DE filter
    Electrical
    360 Degree earth ground @ beam steel
    Sub Panel if required
    Coping Flagstone
    Interior Diamond Brite
    Tile 6 Master Tile
    Decking
    672 Sq Ft of steel reinforced stamped
    176 existing to be topped with stamped overlay
    Tan PVC @ deck joints/PolyVoid composite @ coping
    #3 rebar tied on 18 centers
    Every 3-4 feet tie deck into pool beams
    250ft 4 PVC drainage
    Special Features
    1 3HP pump for vanishing edge
    12 raised spa with flagstone facing
    4 spillway faced with tile
    2 18 sheer descents
    32 raised beam faced with flagstone
    3 18 columns
    81sq ft sun shelf
    11 bench
    12 vanishing edge faced with tile and pump
    1 12 x 12 arbor
    1 natural gas fire pit
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Please review our new IGP build
    VERY cool fire pit!! Looking forward to the construction pictures you're gonna post...right?? ::hint! hint!::
    Gorgeous pool plan, but is it deep enough? I really like a pool I can dive in. Will two LED lights be enough in the pool considering the way the walls may occlude some of the light from around the firepit walls, etc? I don't know beans about lights but it might warrant asking?
    No diving!!!! Our 12 year old is a gymnast and if we allow diving, there is no telling what will happen. Specifically wanted the sports pool to play volleyball, basketball, and mostly my own oasis and I am short. LOL Will surely post lots of pictures!!!!
