Results 1 to 11 of 11
Thread: CC level at 65????
    Jun 2013
    Michigan
    24
    CC level at 65????
    Ok, I thought I had this figured out but i'm not sure.
    Testing this morning..
    CL - 5
    PH - 7.0
    TA - 150
    CYA - 30
    CAL - 250
    CC - 65 (13 drops to change the color) x 0.5 = 65?
    I added abt 32 oz of stabilizer two days ago when the level was at 20. It has came up to 30. That CC level tells me to shock. Is that correct?
    All answers appreciated....truly...truly....truly
    St. Clair MI, 18,600 AG, Sand, Hayward Pro Series, Top-Mount, Model #S210T93S, 1+1/2-Horsepower Matrix Pump. Installed June-2013.
    Re: CC level at 65????
    is it possible you grabbed the wrong bottle for the CC test?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    You divide 13 by two. But still, I'd double check the bottles.
    Jun 2013
    Michigan
    24
    Quote Originally Posted by crek31
    Re-testing...will post in a couple.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You forgot a decimal between the two. I think you mean 6.5. I won't tell you to shock until you re-run, make sure you have the right results. Did you get thirteen drops on the first or second part of the test? How many on the first part?
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Oh OK, we are posting at the same time.
    I'll check back in a bit...
    Essential Links:
    Jun 2013
    Michigan
    24
    Ok 14 drops of the R0871, 5 drops of R0003....it is clear. That means I have no CC correct?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yep, 7.0 PPM FC 0.0 CC. Excellent! Your pH needs to come up a little, say to 7.5, but your FC/CC is nice.
    Essential Links:
    Jun 2013
    Michigan
    24
    Quote Originally Posted by Brushpup
    Doing the happy dance!
    Am I correct that Borax will raise the PH without raising the TA?
    Jun 2013
    Michigan
    24
    I did indeed! LOLOLOLOLOL
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Quote Originally Posted by ghetohound
    Yup- use the pool calculator to determine how much but its prudent to use less than suggested and retest. You can add more if needed but you don't want to overshoot if you can avoid it.
    Sometimes folks aren't positive of how many gallons their pool actually holds so this practice of under-dosing at first helps you determine how accurate your volume is as well as avoiding any testing variables that might cause you to over treat by accident.
