Thread: How to Wire LED MagicStream to Easy Touch
    I have finally started my 18'x42' inground vinyl liner pool. Things are moving well except for the Pentair Laminar Jets. My question is do I run a 110v circuit from a transformer back to the easy touch8? And as far as the 1"ball valves required per jet which I have 4 jets ,where do I place them since my run is 100 feet from the heated equipment room? Do I run a manifold back to the equipment room or do I run 2" to another manifold in the concrete deck closer to the jets?
    Thanks in advance I have to sort this before noon tomorrow
    Building year round use outdoor in ground pool in Wisconsin
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Re: How to Wire LED MagicStream to Easy Touch
    Sorry, can't answer the valve question but on the lights, you will run 110 from transformer to relay. Your breaker (load in) will run to relay.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    The ball valves are generally only used once to setup the flow rate for each jet so they are balanced and look good. It is actually common for them to be buried near the jets, though really you can place them anywhere along the pipe you want, and you might need to adjust them someday so I don't really recommend burying them.
    Thanks Guys that was very helpful, I have my hands full here with this diy build.
