Thread: Question about adding chemicals??
    Is it okay to add dry acid right after adding bleach or do I need to wait? If so how long? Also, I leave my pump filter running all day and night. Is that okay or should I only run it for 6 hrs which is what is recommended.
    Intex Ultra Frame 18x48, AG, 6,423 gallons, vinyl, Intex 635T cartridge filter pump - 1500 gph, No SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Question about adding chemicals??
    Quote Originally Posted by ENCGirl
    Let things mix for thirty minutes between chemical additions. pool-school/recommended_pool_chemicals
    Here's an article that explains pump time pool-school/pump_run_time
    [center:3tlesvoq][/center:3tlesvoq]
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Good idea to wait about 1/2 hour after the bleach.
    Your pump has the timer on it, right? Set it for 4 hours, and turn it on in the AM about 15 min before you do your morning tests. Then again about 15 min before doing your evening tests. Just turn the switch to off then back to timer each time.
    Thanks again!!
