Thread: New Pool Owner
    Jun 2013
    Arlington Texas
    2
    New Pool Owner
    Hello,
    I have read alot of posts before I finally decided to post my results.
    I bought the Taylor K-2006C, with all the fancy testing solutions and followed the instructions to the "T" and my results seem some what off
    Chlorine 2.2 PPM
    PH 8.2
    Alkalinity 180 ppm
    Calcium Hardness 330 ppm
    CYA 120 - 140 ppm (kinda hard to tell since it wasnt close to the readings on the test)
    So after I took my readings down I went to Leslies Pool Supply and got my water tested and these were their results:
    Chlorine 3ppm
    Salt 4200
    Calcium Hardness 200
    Cyanuric Acid 60
    Total Alkalinity 130
    PH 8
    Acid Demand 1
    Copper 0
    Iron 0
    Phosphates 400
    Temperature 85
    So now Im totally confused between the two, who's readings do I trust? Do I trust mine that was fresh out of the pool? or do I trust Leslie's because the guy looked like a total pro doing the water test and had 15 minute old water?
    Any help would be greatly appreciated!!!
    -Thanks
    15,000 gallon pool
    IG Plaster
    DE Jandy Del60
    2005
    SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: New Pool Owner
    Welcome!
    Trust yourself. And check out this thread: inconsistency-in-readings-t61728.html
    There are instructions for testing CYA when it's off the scale in extended-test-kit-directions-t25081.html
    If you've been following the pool store recommendations, it's almost a certainty that CYA will be too high.
    Jun 2013
    Arlington Texas
    2
    Re: New Pool Owner
    Thanks Richard!!!
    Im honored to have you reply to my post. Well I haven't done anything like add the Pool Perfect Phosfree stuff they asked me to buy, so far I only added Muriatic Acid to bring down the PH levels in the pool. As referred in the inconsistency in readings link you posted. I will take new readings once I get the PH level's down to a norm.
    15,000 gallon pool
    IG Plaster
    DE Jandy Del60
    2005
    SWG
