Results 1 to 10 of 10
Thread: First pool, looking for some direction.
    Ok, so the wife talked me into a pool. Bought an Ag pool and the sales man talked me into a simple salt system. Being new to the pool world I listened to everything he told me and took the bait. First off the simple salt system, did I get screwed over? I got my first couple water test done by the pool guy and seems he was making a lot of money off me, so I went to the web and found this website. I got my Taylor k-2006 in yesterday and the first teat results are in.
    TA=150
    FC= 1.6
    CC= 1
    Ph= 7.8
    CH= 140
    I put 3lb of stabilizer in a sock in the skimmer last night. When should I test CYA?
    Also added 80oz of 8.25% bleach last night.
    Guess I need to know what direction to take from here.
    24k Ag pool, cartridge filter, 1.5 hp pump.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: First pool, looking for some direction.
    Wait about a week to test CYA once it is gone from the sock. Give the sock a couple of good squeezes a few times a day and it will speed of the dissolving process.
    The 1 CC means you need to complete the shock process. (You can read more about shocking your pool here. ) With the 3 lbs of stabilizer your shock level is 11ppm. You need to add enough liquid chlorine to bring the pool to 11ppm and keep it there as often as you can until you pass overnight test Use Pool calculator to help determine how much chlorine to add.
    I googled simple salt system and got several responses. Is this what you have? If so do not use it. Adding copper to the water will eventually cause surface stains and turn light colored hair green.
    Love TFP? Become a
    TFP Supporter!
    Ill get on the shock tonight.
    That is the system I have, if I do decide not to use it what about the salt I have added to the pool? Also the copper range for the system is .3-.5, not sure if that makes a difference in the hair and stain problem.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Welcome!
    On the plus side, should you ever decide to get a conventional saltwater generator, you probably already have the plumbing ports you'll need!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    You didn't mention the results of your CYA test. The chemicals that the "Simple SWCG" Co. are having you add are doing the bulk of the work and likely contain stabilizer. Not to mention it could also have been in the chems used for the pool startup procedure by your builder.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    I didn't mention the CYA because I didn't test for it since I just added the stabilizer and wasnt sure how long to wait to test for it. The pool guy's last test for me showed 19ppm.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by Burbs
    How much did you add? I presume he used a computer based system to test it?
    If so, they're hit and miss on accuracy.
    I added 3lb in a sock and put it in the skimmer. I used the pool calculater and it said add 4lb. 3lb was all the sock would hold.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Oh, my bad. You did mention 3lb in your 1st post. That'll bring you to about 35ppm CYA, leave it at that, don't forget to squeeze the sock liberally. Wait about a week and test for cya using the test with the cloudy water in the test tube. For now, start the shock process with the assumption of 40 cya on the chart in pool school. Ignore the salt water table, doesn't apply.
    Quote Originally Posted by Richard320
    Welcome!
    Could you recommend a system or brand to look at?
