Thread: Pressure guage question
    Jul 2011
    Hagerstown, MD
    30
    I recently after 3 years of operation replaced the original Hayward pressure guage on my sand filter. Reason, water buildup inside the guage (alot), presumably condensation or seal (happened overnight). I replaced it with another guage from Lowes (pool section) and low and behold, the next morning I see a small section of condensation on the inside of the lense. The guage functions fine, same readings as original however, I am concerned that it may not last very long due to the moisture.
    I remember reading somewhere on this forum about a liquid filled guage being better than the generic chaeper ones. Is there any merit to that statement? If so, recomendations on where to purchase said guage? If not, where to purchase a better quality filter guage that wont condense overnight?
    Thank you,
    Marvin
    24' x 54" Aqua Leader Influence Above Ground Pool
    Hayward Pro Series S180T Sand Filter w/Zeobrite
    Hayward Power-Flo Martix SP1592FP Pump
    Lamotte ColorQ Pro 7 Test Kit
    Aquabot Pool Rover Jr. Pool Cleaner
    All equipment is hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure guage question
    Yes the liquid ones last longer (I am on my third year). Check out this thread: http://www.troublefreepool.com/liqui...13-t54701.html
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, the gauges sold to the pool market are about as low of quality as can be bought, they are not very accurate and they don't last long
    mas985's Avatar
    Pleasanton, CA
    11,737
    Ebay has quite a few. I would get a 0-30 PSI instead of a 60 PSI only because a pump should never operate above 30 PSI and if it does, you have bigger issues. Here is one example:
    http://www.ebay.com/itm/New-Hydraulic-L ... 3cd2876ceb
    Mark
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I use an all stainless steel Wika 30 PSI liquid filled pressure gauge.
    Thanks!
    David
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
