Results 1 to 7 of 7
Thread: what to use for measuring chemicals?
    Jun 2013
    Newcastle, Oklahoma
    508
    curious as to what you guys use? liquid measuring cups? or do you guys go by weight or what?
    is there a certain kind of measuring cup i should get or do i just go to the kitchen section at walmart and get the biggest oz measuring cup they got?
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,057
    Re: what to use for measuring chemicals?
    I use a 2 cup clear plastic measuring cup. I can read the graduations from above, through the side, so I can keep the acid well below eye level.
    Remember - NO GLASS around the pool.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I use an old 25 oz shaker bottle that we lost the lid to, it's translucent plastic.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2013
    Newcastle, Oklahoma
    508
    thanks guys. ill get me a clear plastic cup in oz
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I use a lexan measuring pitcher from the food supply store. Works great and the measurements are molded in so they can't wash/fade off.
    -- Guy --
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I use a couple of things all of which I store in the pool house- I bought a set of cheap white plastic measuring cups, I also use a old large Brita pitcher which has good markings for liquids and its easy to mix in it and pour. I also recycled some of my husbands large plastic protein powder canisters into containers for the large bag of baking soda and borax - I used my precise kitchen scale to measure how many ounces a half cup equaled and wrote that on the container. So when the pool calculator says add x amount of ounces of something, I've got a rough idea of how much to use without pulling the scale out again.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I cut water bottles down. My CYA cup says 4ppm on it. I don't have to do any math.
