Thread: Getting Ready to add New SWG
    Jun 2013
    Fort Myers, Florida
    11
    Last year I bid on an SWG at a charity auction and won. I know, seems silly, but I had researched them extensively and knew what I was looking for. No one else was bidding aggressively, so I jumped on it and took it home.
    Well, a year later after a complete rework of my home's breaker panel and feed back to the pool equipment, we are ready to install. Part of the package that I bid on included the salt and the startup of the system. I trust the pool contractor that will be doing the work and know the owner's personally. I have a few questions for the group that I will posted under my current test results.
    Test results:
    FC - 21
    CC - 0.5
    pH - 7.2
    TA - 100
    CH - 500
    CYA - 80
    Borates - not yet
    FC is still high from shocking with bleach last week. Overnight drop is zero.
    Should I start aerating to reduce TA before they come to do the install? I will ask if they are going to adjust pH and if not, will handle it myself. I think by CH reading is whacked. I have never had one above 190, so I will test again. Do I need to wait for FC to come down below 10 before they install?
    Last question, I have some staining that I have not identified as of yet. It looks like dark streaks that extend down the wall almost all around the pool. There are also some spots that looked like black algae, but they are definitely stains. Should I deal with the staining before adding the SWG?
    Jason
    1980 vintage, 22K gal, IG plaster, 1.5 hp pump, 175 sqft cartridge filter, iPure SWG, 180 sqft solar heater, Sand Shark Pool Vac, Pool School, TF100 Test Kit, Easytouch 8 (custom expanded valve controllers), 4x MagicStream Laminars, Intellibrite 5g.
    22,548
    Re: Getting Ready to add New SWG
    The TA isn't too high, but I'd do something about that CH if I could. Unless you've used a lot of Cal-Hypo I don't know why it would be that high i where you're located.
    The pH is quite possibly lower than the reading given that the FC is so high. Wait till it comes down before adjusting it. the FC doesn't need to be down before the install, but you can't do anything with the swg until it is.
    I'd wait till you have everything running and balanced before worrying about the staining.
    Jun 2013
    Fort Myers, Florida
    11
    Thanks Dave.
    I will restest next week when I return home and repost results.
    Jason
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    With FC that high, that pH reading is probably wrong.
    Let FC drop below 10 and repeat the pH and TA tests and then see where you are. Check out the highlighted post here, if you have kids.
    Jun 2013
    Fort Myers, Florida
    11
    Good call! I think they would have a lot of fun with 600#+ of salt!
    Ft Lauderdale, Florida
    1,455
    Test your salinity level first, because the use of sodium hypochlorite will add salt to your pool. Depending on which model salt system you have, high salt levels can shut down the salt system and will require draining down some water to get the salt level to the acceptable range. If it's an AutoPilot, there's no problem with too much salt.
    There are several mineral stain removal systems that are quick reacting and can clear up metallic stains within a day or two, that are worth using.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
