Thread: Pool Radius Question...
    Jun 2013
    Omaha, NE
    8
    I'm in the process of installing an 18' x 52" Swim'n Play pool. I've got the ground all prepared, and have begun placing the bottom rails and plates on pavers. I've followed the manufacturer's instructions inserting the rails up to 1/16" from the "stop" in the bottom plates. However, when I measure from center my radius is reading 9'-1 1/2" (Giving the rails a diameter of 18'-3").
    It's a windy day, so not planning on putting up the wall today, but is it normal for the rail diameter to be this much larger than the specified pool diameter (18')?
    It also feels like the radius of the rails themselves almost have to be "stretched" to fit. Right now, there's about a 2" gap where the rails meet in the base plates, and the rails are right about 1/16" from the metal stop (very small tab) in the plates.
    Any insight is greatly appreciated.
    16x32 21K vinyl IG, 1HP Hayward Superpump, Hayward S244T sand filter, Ecomatic ESC 36 SWG, dobberpoolboy manual vacuum
    Jun 2013
    Omaha, NE
    8
    Re: Pool Radius Question...
    Here is a picture of the rails / plate (the blue line is 9' from center stake):
    Casey's Avatar
    SW PA
    10,427
    I do believe your rails slide under those lil clips. You can adjust from there. That's how my last pool was.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Welcome
    Advertised pool diameters are approximations. My 27' is really 26'9" and I have a small gap between the end of the rails and the stop. I knew this before I started as my pool is used and I measured it before taking it down. I also measured the wall length and figured the diameter. If the circle isn't absolutely round you can get different measurements at different points. From your picture I'd move the pavers out a little as the bottom plates can only move outward and you don't want them to come off the pavers.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2013
    Omaha, NE
    8
    Quote Originally Posted by Casey
    That was it! Don't know how I missed that. Once I slid under the tabs everything fell into place. Thanks!
    Casey's Avatar
    SW PA
    10,427
    The little things are easy to miss! They make the job so much harder too! It's always nice to have a fresh pair of eyes to look at it! Good luck with the build and post pics!!!
