Results 1 to 17 of 17
Thread: What level do you keep your CYA, and why?
    Sep 2011
    Atlanta Ga
    310
    Pool school recommends 30-80. That is a wide range. I'm curious what members here do, and why.
    I'll answer my own question: I set CYA to 50 because it is in the middle of the recommended range here.
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: What level do you keep your CYA, and why?
    Right now I'm 35-40 because I plan to use pucks while on vacation this summer and I normally use liquid chlorine. I plan to end the summer around 50 because I get full sun from mid morning to sunset.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    38,371
    Keep reading Pool School.
    30-50 for bleach pools
    70-80 for SWG pools
    On the higher end if you have a lot of sun.
    Mar 2007
    San Rafael, CA USA
    12,082
    Mine's at 40 ppm and I've had it at 30 ppm in the past. I have a mostly opaque safety cover so do not need the CYA to be high because the pool is only open for an hour or two every day though longer (3-4 hours each day) on weekends. I decide to raise it a little to 40 ppm since I only have to add chlorine to the pool twice a week and a higher CYA works a bit better with the chlorine swing from 6 to 3 and back again.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    55 last year... Fell slowly to 45. This year it was less than I could measure when I opened, then I brought it to 40.
    Due to massive rain this year cousin me to drain off several inches more than 5 times the cya is back to just over 30 again.
    Sent via Tapatalk...
    Jun 2012
    Lafayette, Ca / USA
    260
    Mine is somewhere between 40 & 55 ... The CYA test is soooo subjective to my eye. But that level seems to facilitate my swings between CL low levels of 3 vs target 6 when I catch it on the low side. I pretty much try to just blindly (w/o testing) add 1/2 bottle of bleach every afternoon during the hotter days of summer & my pool temp gets to 88-90. Then once per week do the FULL test to get an accurate read on my FC & CC et al and adjust as necessary.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by cody21
    Honestly if it looks good and that works for you I'm sure that's acceptable. My own routine is similar with a lower cya.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    I keep mine around 50. My pool gets a lot of sun and so minimum FC is 4. Which looks just like 5 on the OTO test to me. All I really need to know is if my FC is as dark or darker than the highest color on the quick tester and I'm good, since I test just before dinner when the sun is pretty much done attacking my pool.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Ours is about 40 right now, and we have a SWG so I know it's too low. I've always used the liquid stabilizer but just bought a tub of the granular kind.
    Can anyone tell me what kind of sock to use? A men's sport sock or should I use a ladies nylon knee high?
    Also, why is CYA for SWG supposed to be so high compared to a regularly chlorinated pool?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by mickey4paws
    It's a trade off. Higher CYA lowers FC losses allowing the SWG to work less to keep up. The consistent chlorination of the SWG reduces the risk of allowing algae to get a foothold, so the higher CYA is not as risky.
    Apr 2009
    S.E. MI
    570
    Quote Originally Posted by UnderWaterVanya
    Thanks, that makes sense. On the other hand, with CYA at a higher level, the corresponding FC level has to be higher, and wouldn't that make the cell work harder too? or not?
    Nevermind....I was thinking of shock level you need to be at with the higher CYA, not FC.
    Mar 2007
    San Rafael, CA USA
    12,082
    You might think so but it doesn't work out that way for reasons we don't fully understand. CYA seems to shield chlorine from breakdown from sunlight with a mechanism beyond just being bound to it, perhaps shielding lower depths from UV (though some sources say that shouldn't be the case). So even though the FC is proportionately higher so you've got the same active chlorine level while having more chlorine bound to CYA, the overall FC drop is less. This post shows the effect where the FC/CYA ratio is kept constant so the active chlorine level is the same, but the % Loss is lower at higher CYA and enough to make even the absolute FC loss lower.
    Jul 2011
    Hagerstown, MD
    30
    I keep ours at 50 as we get a lot of sun and minimum FC 4.
    24' x 54" Aqua Leader Influence Above Ground Pool
    Hayward Pro Series S180T Sand Filter w/Zeobrite
    Hayward Power-Flo Martix SP1592FP Pump
    Lamotte ColorQ Pro 7 Test Kit
    Aquabot Pool Rover Jr. Pool Cleaner
    All equipment is hard plumbed
    Interestingly, there has been some new studies that CYA is best at no higher than 50. In public pools, especially indoor pools, new recommendations are as low as 20!
    I'm actually coming around to the idea of keeping my CYA level at about 50-60 this summer instead of the usual 75-85.
    http://www.ppg.com/chemicals/accutab/Si ... visory.pdf
    http://standards.nsf.org/apps/group_pub ... -store.pdf
    http://www.poolspanews.com/chemicals/is ... side-.aspx
    18K inground pool, negative edge, original blue black plaster, completed March 2006. Cartridge filter pump, SWCG, Ozone.
    38,371
    We too recommend 20-30ppm for indoor pools, only reason it is that high is because the tests do not go lower.
    If you have little sun, you may get by with lower CYA with the SWG. Otherwise the cell is just going to have to work harder by running more and shortening its life expectancy.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by agogley
    Actually, the proposed Model Aquatic Health Code (MAHC) Disinfection and Water Quality Module prohibits CYA from indoor pools and high risk venues, but they may change that to just limit to a low CYA level. The first source limits CYA because it would be too hard to shock (raise the FC) if Cryptosporidium is suspected, though if one used just 1-2 ppm chlorine dioxide overnight then that would be sufficient.
    As for the sources that say CYA doesn't do anything above 50 ppm in terms of protection of chlorine, that is baloney. It's just that in high bather load pools there isn't much benefit seen above around 30 ppm because the chlorine loss from bather load exceeds that from sunlight. However, in residential pools that are nearly all very low bather load, nearly all the chlorine loss during the day is from sunlight and higher CYA levels most certainly do protect such losses, even if one raises the FC level to keep the FC/CYA ratio constant (i.e. the active chlorine level constant).
    Apr 2009
    S.E. MI
    570
    Quote Originally Posted by chem geek
    Thanks so much for the reply, Chemgeek! I knew you'd be great at explaining it. It really does seem to make a significant difference, for example just in the numbers between 50 CYA and 80 CYA. I'm going to do another CYA test this morning. Yesterday's was only 40 CYA. I still don't feel totally confident in the results because for me, the CYA test is a hard one to read accurately.
