Thread: how to clean the comparator for K2006 test kit
    Aug 2009
    SF Bay Area (Lamorinda), CA
    122
    My comparator has accumulated a bit of cloudy residue over the years. Do you clean it out with a vinegar solution or something else? Thanks!
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    Clear ThermaTex bubble cover
    Manual vacuum
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: how to clean the comparator for K2006 test kit
    I'd try having it soak in some concentrated bleach or chlorinating liquid (not sure how long it would take) and then thoroughly rinse it out many times. You can always get a replacement tube if you can't get that one clean.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Try a bottle brush and soap.
    Sent via Tapatalk...
    I use muriatic acid. Make sure that the tubes are rinsed well before and after.
    Just fill the tube, let it sit for about 20 seconds and pour out the acid.
    Be careful with acid.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by JamesW
    Lab glassware is usually cleaned this way for the sort of testing we do here. You can dilute it down pretty far and it will still be very effective for cleaning glassware or plastics. And no, it will not harm either. Be careful, and remember...when making acid dilutions, Acid to Water....not Water to Acid. I use straight 31% straight from the bottle myself. Up to you....
    Essential Links:
    Aug 2009
    122
    ah yes, acid washing lab ware, how could I forget (well it's been about two decades since I last used a UV/Vis spectrophotometer and had to clean the cuvettes...) Thanks!
    Manual vacuum
