Results 1 to 14 of 14
Thread: Review my plan
    Feb 2012
    Maryland
    400
    Review my plan
    In preparation for filling my new pool, I am trying to document the startup process
    First, the numbers for my fill water. No iron or copper in the fill.
    alkalinity - 350
    calcium - 20
    ph - 6.8
    After filling these are my targets
    FC - 24 (need to add 11 96oz bottles of 6% bleach)
    CYA - 60 (I need to add 176oz of stabilizer)
    PH - 7.5 (target here due to TA being high) (add 821oz of borax)
    CH - not thinking about this yet.
    Salt - 3200 (add 600lbs of salt)
    Borates - not thinking about this yet.
    My questions are
    1. Do I wait until the pool is full to start adding chemicals or should I add some as it fills?
    2. Do I dose at suggested levels immediately or dose at half, check and dose more as needed?
    3. Is there any order at which to dose, ie salt first, then bleach, then stablizer, then borax?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    38,251
    Re: Review my plan
    Slow down. You do not want to try to do everything at the same time.
    Fill the pool and then test it.
    You do not want to raise the FC that high with 0ppm of CYA in the water. Just put 2ppm of FC in the pool and start adding CYA.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Review my plan
    Slow down! There's no need to shock with fresh clear water.
    If you set it up to fill with the hose splattering the surface rather than submerged, it will be noisy, but it will also aerate and probably raise pH some at zero expense.While you fill!
    Get the pump circulating and be sure there's no leakage. Then add 2 ppm chlorine, see if pH needs raising after half an hour or so of circulating. The CYA can get tied up and suspended any time there. You'll be losing a lot of FC initially because of no CYA in the water, so keep close tabs on it. Just keep checking pH and FC and keep them adjusted and raise FC after the CYA is noticeably dissolved.
    Borates are entirely optional, some of us never use them.
    Get things balanced using bleach, then add salt, then fire off SWG. Check out the highlighted post here, if you have kids.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Review my plan
    And once you start thinking about CH remember rainwater is your friend.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Feb 2012
    Maryland
    400
    Re: Review my plan
    Wow, glad I posted!
    I just thought I needed to shock it initially.
    Why do I target FC = 2? If im using the pool calculator properly, it says 4 and CYA of 60.
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Review my plan
    Quote Originally Posted by ssgumby
    Wow, glad I posted!
    Because the CYA doesn't dissolve right away. Your initial reading on CYA will be zero. Therefore, FC has to be lower. Unless you like white bathing suits with rotten elastic.
    Were you planning on spending the extra for liquid stabilizer? If that's the case, CYA will be up to 60 within minutes and you can follow the pool calculator from the get-go.
    Feb 2012
    Maryland
    400
    Re: Review my plan
    Quote Originally Posted by Richard320
    Wow, glad I posted!
    Yes, ill get liquid stabilizer. Is there a name brand that is best?
    I just really want to start off right so im trying hard to plan it out, and I VERY much appreciate this site and the advice!
    Apr 2012
    SW Ohio
    456
    Re: Review my plan
    All brands are about the same just make sure it is 100% cya / satilizer....check prices for the best deal
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    Re: Review my plan
    You could also add enough liquid stabilizer to get you to 30 ppm and then add the rest in granular form and save some money but always make sure the pump is running whenever you add chemicals to your pool.
    Feb 2012
    Maryland
    400
    Re: Review my plan
    ok, after looking at liquid stabilizers I think I WONT be using them ha ha. If im using the pool calculator right it is telling me to go from 0 to 60 I would need 4,567 ounces!!! To get that I estimate I would have over $1000 in stabilizer! crazy
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Review my plan
    Better check your math or a typo in the calculator. That's about 10X as much as I would expect.
    If you make mistakes like that with all the chemicals, you"ll never ever get the pool balanced.
    Feb 2012
    Maryland
    400
    Re: Review my plan
    doh, the volume of my pool is 22,000 ... the pool calculator had an exta 0 So it was calculating 220,000.
    No worries, I wont add anything without checking and confirming! Ive run through this many time so far. Hope to start the fill by thursday.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,077
    Re: Review my plan
    Just up it to 30 to start. Once it's dissolved it's in there working. Often all mine takes a day or so to dissolve. It's best to sneak up on this level anyways, as reading the test at first can be tricky.
    Jun 2011
    Long Beach, CA
    2,778
    Re: Review my plan
    Just a small tip for you if you have a water meter that you can read, take the reading before adding the water and after so you will know exactly how many gallons the pool holds.
