Thread: Hello from Virginia
    Jun 2013
    Central Virginia
    13
    Hello from Virginia
    Hi. I live in central Virginia. We have a very large (55,000 gallon) "L" shape vinyl pool. The pool is 25 years old, but the filter is 10 years old, the pump I replaced last year and we just replaced the vinyl this year.
    Stupid design - there are two skimmers and no main drain. Despite this, it stays remarkably clean. Our second robot cleaner just died and I'm researching replacement robots. I'm presuming (valid or not) that the cleaner will only last 2 or 3 years and, therefore, I don't want to spend a fortune on one.
    Thanks for having me here! -- Matthew
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hello from Virginia
    Welcome to tfp, b6283
    I can't answer you question on the cleaner, but that seems like a short life. Did you attempt to troubleshoot and replace failed parts?
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Can we see a pic of the pool?
    You're done SLAMing when:
