Thread: FC and CC Readings
    Kentucky
    56
    FC and CC Readings
    I'm testing using the test kit recommended by TFP. When I test the FC, do I wait until the water turns clear permanently or turns clear the first time? When the water initially turns clear, I turn to record the # of drops, it's back to pink. I wind up adding 3-5 more drops before it turns permanently clear. I think this has an effect on the CC readings (the next step).
    I have added 23 gal. 8.25% bleach the past six days.
    What is the rec'd CC level; it doesn't show in the Pool Calculator?
    16' x 32' vinyl with 8' deep end, appx. 21K gals, 1 hp Water Ace pump, Hayward Vari Flow 75gpm sand filter, 3 returns, 2 skimmers, 2 main drains, Dirt Devil robotic cleaner.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: FC and CC Readings
    What are you getting for CC? Is this with the extra 3-5 drops during the FC portion of the test, or without?
    What is your cya level?
    What was it when you closed last year?
    What was it when you opened this year?
    Quote Originally Posted by Larry65
    There isn't one since you want CC<0.5 ppm.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I just saw that you have a thread going dealing with your current issue. Please keep your posts there since the answer to my questions where in that thread.
    Kentucky
    56
    Sorry, getting frustrated will keep all posts in other thread, "Starting Over--"
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    No problem, it is easiest for us to help you if we have your issues full history
