Thread: Liquidator CL level??
    When my pumps turns off, the remaining suction draws the liquidator level down and into the pump suction piping until the liquidator outlet float stops this process.
    Should I be concerned that a "high chlorine level" water slug is sitting in my pump suction (and pump) overnight?
    I don't see any way to prevent this and have seen other threads where people see the same thing happen.
    17K Plaster Kidney (17' x 37') w/ Spa
    Jandy DE filter, Jandy JHP 2.0 pump, Polaris 280 cleaner, Stenner set up with bleach
    Jandy LJ Heater and Aqualink RS controls
    22,537
    Re: Liquidator CL level??
    It's not a problem. The water that's being drawn out of it is only a couple ppm higher in FC than the pool water, so it's not going to hurt anything.
