Results 1 to 7 of 7
Thread: Good grief! Intex SWG "High salt" reading -no salt added!
    Siphoned to waste yesterday due to a layer of fine silt that refuses to leave pool bottom- so I added fresh tap water to pool- nothing more. This morning I get "high salt" reading. What the Sam Hill? I thought it would be "low salt" if anything.
    So unless anyone here can offer me a reason to believe that reading, I'll be taking my SWG apart for cleaning this afternoon.
    ~25,000 gallon
    In Ground Pool
    Gunite/Plaster/DE Filter
    Using a TF-100XL from http://tftestkits.net
    Dolphin Dynamic bought 4/2013-pretty happy with it
    22,542
    Re: Good grief! Intex SWG "High salt" reading -no salt added
    Do you have an independant salt test? If not, take a sample to a local pool store and have them test the salt. I doubt that it's high unless you just added some and it hasn't had time to mix yet, but you never know.
    To clarify- there is salt in the pool water I just did not add any more.
    ~25,000 gallon
    In Ground Pool
    22,542
    Some places have a pretty high salt content in the tap water so you may not have removed as much as you think. I still would have it tested.
    Thanks Bama. I completely forgot about salt tests! I'm still in 'Don't have time for that!' mode.
    ~25,000 gallon
    In Ground Pool
    I unplugged the pump for an hour, plugged it back in and now everything seems to be working fine. Go figure. I'll take it!
    ~25,000 gallon
    In Ground Pool
    Mine will do this sometimes, I just installed mine last week and manually turn it on most days. When I allowed the timer to turn it on (only twice ive done this) it told me both times high salt. Turn off the pump...turn it back on and it worked fine. Kind of annoying but I have installed a timer anyway for the power so I can do half my pumping at night and half midday just to keep the water cleaner more of the day. Anyway this has worked for me so far.
    Intex 22 x 52 Ultra, Intex 16" Sand/Saltwater combo
