Thread: Air bubbles out of one return jet
    Jun 2013
    Lawrenceville GA.
    53
    I have two return jets. I'm getting air coming from jet closest to pump. Never from jet furthest from pump. I have not noticed air in the pump basket. Also when first turning on pump I get an initial shot of air bubbles. The bubbles dissipate after about one minute. But after about an hour the bubbles are back. And pressure has dropped about 5 to 10 psi. I can turn off pump for 10 to 15 seconds and restart it and the above cycle begins again starting with normal pressure and the initial shot off bubbles. Any thoughts on this?
    16x32 IG, 24k Gallon, Vinyl, Sand filter, SWG
    Jun 2013
    Lawrenceville GA.
    53
    Re: Air bubbles out of one return jet
    Also, I don't know the size of pump or filter but here is a pic. Its a single speed pump as far as I know.
    DeeMac's Avatar
    May 2012
    Munster, IN
    123
    Try running some water over your pump basket. If the air pocket in the pump basket goes away, probably a bad seal.
    16 x 34 inground vinyl pool
    Hayward 1 hp super pump
    200s Hayward Sand filter
    Jun 2013
    Lawrenceville GA.
    53
    I will give that a try. Thank you.
