Thread: How long does the pump need to run after I add stabilizer?
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    How long does the pump need to run after I add stabilizer? 24 hrs like salt?
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Best way to add Stabilizer
    I use a Tide Bra Wash bag. I place it in the mouth of the skimmer with one section of filter hose to ensure it doesn't suck into the basket. It's gone very quickly. The bag has a fine mesh.
    http://www.target.com/OpenZoomLayer?tem ... ageCount=2
    -- Guy --
    22,553
    The pump should run until the CYA is dissolved if you put it in the skimmer in a bag or sock. It can run normal run times if you hang it in front of a return, but it's still best if it runs until it's dissolved.
