Results 1 to 8 of 8
Thread: New pool owner, give me your suggestions
    May 2013
    Leesburg, Mississippi
    14
    I have a Intex Ultra frame 16x48
    I just added the SWG and sand filter last night.
    I added two 40 lb bags of salt last night.
    Here are my results this evening and the alterations I have made:
    FC 4
    CC .5
    PH 7.2
    TA 110
    CH 40
    CYA 30
    Salt 2400
    I added 20 oz of stabilizer to bring up CYA some more.
    I added around 25-30 lb of salt to get over 3000.
    I an aerating now to bring PH up so I can lower TA with acid.
    I am going to let the rest of the salt dissolve tonight and turn on the SWG tomorrow night.
    Any suggestions would be appreciated.
    Daniel
    Intex Ultra 16'x48" Round AGP-5000 gallons
    Intex Krystal Clear 2650 GPH SWG & 16" Sand Filter
    Intex LED Light
    TFTestKit-100---Pool School---Pool Calculator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New pool owner, give me your suggestions
    Welcome to tfp, oldtoyboyd
    How does your water look?
    Your plan sounds good!
    30,421
    Very good plan. I would leave pH and TA right where they are. pH will likely drift up a little on it's own and TA is fine (it will slowly lower on it's own, as well)
    Nice work
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    , and Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi, Daniel, and welcome to the forum
    Very nice first post, you have a great handle on things.......and love your sig
    You're done SLAMing when:
    May 2013
    14
    I have had the pool setup since Memorial Day.
    I just got the sand and SWG in the day my cartridge filter plugged up.
    My PH this morning was 7.5
    Here are some pics of it:
    Here are some pics of the water:
    Intex LED Light
    May 2013
    14
    Quote Originally Posted by Butterfly
    I have been lurking for a while, gave me plenty of time to get a good sig before I posted.
    Daniel
    Intex LED Light
    May 2013
    14
    I tested this afternoon:
    FC 4.5
    CC <.5
    PH 7.5
    TA 110
    CH 40
    CYA 60
    Salt 3200
    I think I will turn the SWG on tonight.
    I got a thru wall skimmer that I am going to add and hard plumb it to.
    Have to see how time goes this weekend.
    Intex LED Light
