Results 1 to 7 of 7
Thread: PLEASE....I need serious help!! LOTS of Calcium buildup
    I have an AG, 2nd summer this year. I have thick, and I mean thick, calcium buildup along the walls and cannot get it off! I've read numerous posts on here about using Muratic acid and plugging in numbers into the calculator to determine how much to use. Apparently I'm not smart enough to figure the calculator out.
    So...can someone please help me. I'm getting so disgusted with this pool I'd really like to drive my truck into it.
    22k gal., AG, 1.5HP Hayward, Cart. filter, Swimpro Voyager, Model #CC1750, Flow Rate 110 GPM, 06/2011 install, and I also have an automatic chlorine feeder if that matters.
    FC - 1
    CC - ?
    pH - 7.5
    TA - 160
    CH - 250
    CYA - ? cannot figure out how to do this test apparently. I think this was the test that the black dot "dissapears"?? Well, it never did.
    22k gal., AG, 1.5HP Hayward, Cart. filter, Swimpro Voyager, Model #CC1750, Flow Rate 110 GPM, 06/2011 install, and I also have an automatic chlorine feeder if that matters. Troy, Mo.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: PLEASE....I need serious help!! LOTS of Calcium buildup
    Welcome to TFP
    To figure out the amount of a chemical to use, enter your pool volume in the orange field near the top. Then, enter your current test results in the "Now" column and your desired levels in the "Goal" column. Hit the tab key or press the Calculate button at the top of the Pool Calculator to see what chemical & dosage you need to add to get to your goal levels. BTW, your current CH numbers look good.
    BTW, here is a great post about managing Calcium Scale
    Quote Originally Posted by tdrumm1
    If the black dot never disappeared, then your CYA is less than 20 ppm. You want to aim for a minimum of 30 ppm. Here are the Extended Test Kit Directions that may help with your testing procedures.
    A couple of things to help us help you...
    • 1. Please add to your profile the state and nearest city in which you live. Your climate is important to the advice you receive. By doing this, it will appear in all your posts without you having to enter it each time.
      2. Suggest adding information about your pool and related equipment in your signature. By doing this, it will automatically appear in all your posts so you do not have to re-enter it each time. If you have a SWG, please include those letters in your signature so it stands out as the advice for SWG vs. non-SWG is often different.
    Here's how to do both of the above: Adding location to your profile and pool info to your signature.
    One final comment: What are you using to test with? If you don't already have one, you will need a good test kit to properly manage your pool. Here is a comparison of the recommended Test Kits.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,397
    Hi, welcome to TFP! What kit are you using to test the water?
    Love TFP? Become a
    TFP Supporter!
    I am currently using a hth kit from the local retail store, because I think the strips Watson's gave us with the pool are pretty much useless. Please forgive my absolute ignorance in regards to all things pool related, but I have no idea what an SWG is. I have looked all over this site for a definition and haven't found one. So...I don't know if I have one or not.
    I appreciate your response BoDarville, but I've read the information on the calcium scaling but it's not helpful in removing it from my pool. I have a vinyl liner and they are scrubbing off of tile, etc. Also, I'm sure all of you that run this site have probably written these instructions numerous times but I seriously need someone to "dumb" this down for me. I just need to know what to do. Also, if my CH seems fine why do I have such horrible scaling? It's seriously so bad that in spots you cannot see the liner! Ugh......so frustrated!! I called Watson's today and of course they were anything but helpful. Can this problem even be fixed?
    Thanks again!!!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Welcome
    SWG = Salt Water chlorine Generator also SWCG.
    Could you post pics of the scaling? Thick to you might be something else to us.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    You may have to drain and acid wash or even buff the calcuim off if its really bad.
    There are stories of people getting it off by reducing the pH of their water, but I had to buff and acid wash a friends pool a couple of years ago because they did not watch their water.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Can u acid wash an AG with vinyl liner? Here's a few photos from my IPhone, but the scaling is under the waterline extending to bottom of pool and feels like concrete. Thick enough to not be able to see the liner in some places.
    * sorry photos too big to upload, I'll try on my laptop tomorrow.
