Thread: Stenner Pump Rates Spreadsheet
    May 2013
    North East Ohio
    959
    So I've been searching till my fingers are bleeding...
    Anyways, before I decided on the Stenner setup, I swear I saw a spreadsheet that someone built that shows how much time the pump should run based on dose, etc.
    I know I could recreate, but it was really cool and done as well.
    Anyone know where it might be hiding ?
    Thanks!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    May 2012
    North of Charlotte, NC
    312
    Re: Stenner Pump Rates Spreadsheet
    PM me your email, I have all 3 spreadsheets on my PC , dont know how to attach in a post....Can email them to you....
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    May 2012
    312
    [attachment=0:2h47duiz]Stenner Pump Flow conversion.xls[/attachment:2h47duiz]
    Attached Files Attached Files
